21 - 40 of 69 Posts
Did anyone ever confirm this? I need to do this today for my JRSC/K24a2! TIA
I can only find a -10AN fitting to a -10AN barb or a 5/18" barb (-10AN has an O.D. of 5/8 anyway im pretty sure, so they are the same).
Im sure i can get the hose to fit over the end of a 5/8" barb, its only slightly larger.
So im going to get:
1. 3/8 NPT tap
2. 3/8 NPT to -10AN male
3. -10AN to 5/8" barb
sorry to bump old thread.
just confused with tap sizes at the moment.
ive been told to use 3/4" tap for coolant port and 1/2" for EGR.
this is what i find strange.
clubrsx said to use 3/8" tap for coolant port? but isnt 3/8" = 9.5mm
wouldn't 3/8" be too small for the coolant port?
wouldn't 1/2" be too small for the EGR port?
coolant port has smaller hole diameter (13.45mm)
EGR port has larger diameter (18.95mm)
http://www.ephatch.com/forum/showthread.php?61473-k24a2-Coolant-port-tapping-and-fitting-size&
http://forums.clubrsx.com/showthread.php?t=644703&page=3
from google tap searches, it shows that i should be using:
coolant port (13.45mm) = 5/8-11 tap
EGR port (18.95mm) = 7/8-9 tap
http://brassmein.com/tech/taps.htm
if you can shed bit more info/clarification please.
thanks k20a.org
21 - 40 of 69 Posts
