diy|faq ☆★☆★☆★☆★ diy|faq ★☆★☆★☆★☆ diy|faq
Comments, Suggestions, and Submissions are Welcomed
If you do not see the information you are looking for here, check the Stickied threads in the Subforums. If you do not see what you are looking for, you can search the entire site, or narrow the search to a specific subforum. It is best to ask a question in a related thread, this keeps the information organized and it also helps others find information in older threads.
If you would like to contribute, just post it up. Show us what you got too, pics are what we need the most. Please use the 'attach' option when posting, so that in the future the picture is still available.
If you want a Factory Service Manual, you can buy it here HelmInc.com or get it here by member @Them Witches: manuals for TSX and RSX.
Some online archives for FSMs
EVEN MORE FSMs
INDEX
Below are links to posts in this thread that cover a topic.
BUILD THREADS
Blocks / Cranks / Rods / Pistons
Body / Chassis / Cosmetic
Engine Accessories / Ignition / Pulleys / Power Steering
Engine Differences
ECU / Engine Management / Tuning
Engine Builds!
Forced Induction (Turbo / Supercharger) and Nitrous
Frank Info K24/K20
Fuel System / Injector info
Head / Cams / Valvetrain / Intake Manifolds / Throttle Bodies / Headers
Heating / AC
Oiling systems and components
Shifter info
Transmission / Axles / Flywheel / Clutch
Swaps and Parts lists
Wiring and Pinouts
EVEN MORE FSMs
INDEX
BUILD THREADS
Engine Differences
Engine Builds!
Frank Info K24/K20
Heating / AC
Shifter info
Wiring and Pinouts
