161 - 180 of 349 Posts
what about the axles. the base model rsx vs the type s. are they both the same size in thickness. im talkin about the part that goes inside the tranny. becasue im running base model rsx axle and it has some play. any advise? thanks in advance
Are u trying to swap the b series inners to make it work wit the type s axels ?because Iam not 100% on that qestion I bought axels that went into my trans for a type r k20a trans in an eg dident take the cheap route
have a 2006 tsx motor going into a 2000 civic coupe, will a 2002 charge and wire harness work?? im starting to peice every part i need together. if anybody has parts dat i would need for swap like axles, trans cables, karcepts shift box, etc...please post here. pretty much need it all. got motor and tranny. help me out dudes. gabe
Discussion starter · #171 ·
There's so little difference between the two swaps it's not much use to do so.
-Froth
As everyone else, im piecing together and got a complete k24a1 and complete k20a2 (hydrolocked) Doing k20/k24. Your list looks great as im doing it into an eg also.
With all the bonus parts i got in the motors, will the rsx s idler pulley work in place of the ep3 idler pulley? Sorry but i can't find the specs on both. :cool:
idler pulley for the rsx? the rsx uses a power steering pump (hydralic) and the ep3 uses a idler pulley since it has eps.
People run the EP3 idler pulley to remove the a/c and p/s. The pulley is really there just so that the belt can route correctly over everything i'mm sure.
You can use that or get one of the karcepts / k-tuned kits. Both do the same. The karcepts/k-tuned relocate the alternator and it cleans the bay up nicely.
Next swap i'll be using on of those rather than the EP3 pulley.
Discussion starter · #179 ·
I'm more a fan of OEM parts than anything aftermarket, OEM is reliability second to none. I'm not knocking anything you mentioned but between the two I'd go with the OEM setup every time.
-Froth
-Froth
It's good to be able to have a choice :up:
For the older chassis', the aftermarket kits allow re-location of the alt for hood clearance so thats a benefit of those ones.
