181 - 200 of 349 Posts
that makes sense on why i couldn't find my answer. Maybe i already have the ep3 idler pulley then. I will check out the karcepts option too. Thanks guys
the idler is circled. the other one is the a2 from the rsx with the power steering pump.
Jackson Racing Pulley - P/N: 052-154 (This will clear an EG hood with K20 swap, no hole...only cutting.)
hi every body, is anybody have measurment of this pulley?
after so many research i finally found a website which can have it (i'm french so i order it from UK, there is no JR seller in france :() but it cost 140€ shipping out :wow:
just for a pulley.... i think it's very expensive :wow:
so i'm looking for people who can measure their pulley in order to see if another one is compatible
thx a lot for your help, i'm boring about driving without PS :eek:
i am starting a k20r swap in a 00 civic si this weekend i am swaping out a b18c type r for the kseries. i have bought the hybrid swap header from hybrid racing i am curious it only has 1 o2 hole and there are 2 o2 sensors if im correct? so do i drill and tap? and i thought i mite have read on here that u can eliminate 1 o2 sensor with kpro corect me if wrong. got everything to do swap just wanna be prepared for the last thing im curious about
any suggestion greatly appreciated
Discussion starter · #185 ·
K-pro only needs one O2 sensor to work correctly, You could have another one welded in after the Cat if you wanted to remain legal...but it's not necessary.
-Froth
ok so kpro you use 1 o2 sensor wat about using the jdm type r computer b/c i am gona buy a kpro in the future but wanna put the k 20r in this weekend and dont really wanna cut hole in header and weld stuff feel me where i live we dont get tested for emissions and my buddy inspects it so legal is basically watever lol
I will be purchasing a rsx type s soon. I have an EK9 and I want to swap the k20 into the EK. My question is, can I use all the parts listed straight from the rsx? And is there anything I will absolutly need? I already know about mortor mounts. But I don't want to have to buy so many parts since I don't have such a large budget.
Discussion starter · #188 ·
The list is just that, a List of EVERYTHING you will need to have a running K-swapped car. Check off everything you have on the RSX-S and the rest is what you'll still need to purchase. K-swaps still aren't B-series cheap, but they've come down a bit.
-Froth
Discussion starter · #190 ·
Yep, Just do your research. There are tons of helpful hints and many many knowledgable members on this site...and welcome!
-Froth
finishing up a k20 type r in a 2000 civic si so i used the karcepts shifter mount kit and im using the hybrid racing swap racing header i was under the impression i was able to keep and use stock exhaust length and i was wrong i have new 2.5 inch catback and now i need to hack up and the header is close to the shifter mount which makes it a weird angle so i gues i have cut and get a pipe bent to fit any suggestions everything else is done besides waiting on on a slim fan shroud because stock fan shroud wouldnt work with aftermarket rad :confused:
hey i got a problem i have an 2005 rsx k20a3 that i blew on a misshift and i currently swapped it out and tried putting an 2002 k20a2 motor in using a kpro after everything was installed the car started up but then bogged out and shut off on me. I contacted hondata and they said that i cant use the 2002 engine harness in the 05 so i got a 05 type s engine harness and put it on but now its not reading the kpro i had the kpro upgraded to be used on an 05 rsx but still nothing at this point i have not a clue what to do my car has just been sitting there for the past few months. Has anyone here ever done a swap like this before and was sucessful at it that can maybe help me out because i really need some help, im stuck between a rock and a hard place right now
i have a 95 four door which you know already...........can i use my stock radiator that came with the car......and do i have to get a 3" pipe kteller isnt there anything else like what would happen if i get a 2.25'pipping.........??
Discussion starter · #200 ·
I do believe they will all work the same.
-Froth
