201 - 220 of 349 Posts
2002-2005 Acura RSX (K20A3) have 5-speed transmission and 2002-2004 Acura RSX Type-S (K20A2) have 6-speed transmission. is 2002-2005 Acura RSX (K20A3) shifter box work with 2002-2004 Acura RSX Type-S (K20A2) 6-speed transmission???
Discussion starter · #202 ·
Yes. I believe the boxes are the same.
-Froth
Discussion starter · #212 ·
Is it possible if I just want a power steering but I don't want to have an A/C?
How about I don't want to have a power steering but I want to have an A/C?
Thanks.
They are both possible with the correct parts.
-Froth
Hi, I have a 02 rsx-s and am planning to do the frank swap. Need a little help to clear some things from my mind. As mention, I will need to get the crv pass. mount? ( I already have 4 85a mounts from inno., so I would have to replace the said inno. mount with the crv? wouldn't that make that side vulnerable?)
Also, as for the engine sensors, do I just replace the k24 bottom senors with my k20a2 senors? and just plug the harness together how everything was?
soo, ive had my k20a2 swap running for the past year and 2 months. i meantion this because i want you all to know its all in working order and everything, and has all the necessary parts to make it run, and with the type-R ECU.
my question is, if i wanted to swap out for an 04-06 k24a2 longblock with no tranny, what else would i need with the parts i already had on my working k20a2 swap? i know the passenger CRV mount, but would i need a whole lot more added with the parts i already have on my k20a2?
looking at the parts list on page 1 is kind of confusing, seeing that i dont remember ever single part i already have. and if this question was asked already, then my apologies. i didnt want to read through every single page.
and my car is an 00 civic coupe.
im pretty sure a k24 shortblock would fit under the head. if you use all the k24s belts and chains. not sure what you would need different and a tune
id prefer just a straigh out TSX swap. i feel it would be more reliable than going to a frank build.
i think i change my mind on wanting to keep my k20a2 in there after seeing how quick everyones k24a2 motor runs, even in a coupe. like the 99-00 Si coupe, theres a few people with them on here, and they're like 100lbs heavier than my 00 EX coupe, and just a couple bolt ons and a tune, watching their speedometer needle go around, it looks alot quicker than my k20a2. i like the extra torque :)
if i can get someone to trade for my k20a2 longblock, i would love to swap out for the k24a2...if there isnt a whole lot i will need so i can make it work with everything i already have on my k20a2 swap. i will use my Type-S tranny as well. and i only have the JDM ECU. so im not sure if it would work with the k24a2.
2.0 ecu runing a 2.4 it would work but id deff be carfull & get kpro.
and gl i just got a 08 k24a2 longblock i cant wait!
