141 - 160 of 349 Posts
are the bolt patterns on the K24A2 and K20A's water passages the same?
i.e.
can i use a EP3 idler pulley on my K24A2 motor, will it bolt right up?
if not, are the water passages on the 2 blocks (20 & 24) the same internally? are they interchangeable
i have a feeling the idler pulley will work just fine but ive not had one on my car, and i have K24A2. just want to make sure before i buy things.
Discussion starter · #146 ·
To do everything right, cutting no corners you're looking at $8,000-$10,000+
-Froth
stupid question but here it goes.
for an EG chassis, are you saying that If i put in a k24a1 bottom end in the bay that the CRV pass mount will only work/fit for thw K20/24swap? cuz I just ordered the HAsport mount kit so I wanna know if Ill be needing all 3 mounts from HAsport or will I need to make a call to Honda to get a Mount seeing as my K24 didnt come with mounts:(
EH1_Frank I sent you the info you need in a PM.
The part # for the CRV passenger mount bracket is 11910-PPA-000
Harness Conversion(Hybrid/Hasport/Sparkks)
Question regarding this. I have a OBD2B to OBD1 conversion harness that fits between my old ECU and my vehicle harness.
I have a PNF Ecu, do I just plug it in directly into the vehicle harness? Or does the K series SWAP harness go in between the ECU and vehicle harness? Thanks. :up:
Hey I know yall get tired of hearing the same questions and people askin for help on everything but I just picked up a 95 integra ls shell for 100 bucks and puttin my k20a3 in it. Is there a way I can keep ac and powersteering? I've searched all over the threads and can't find n e thing about saving ac. Just wanting to know thanx guyz.
search a lil better man. I even think its a sticky somewhere....
PS is easy, AC hybrid makes a bolt in kit or u can get custom like I am.
i dont mean to sound dumb since im kinda new to this k series stuff so forgive me if i do but the spline that goes into a k20a2 tranny, is it the same size for a type s and a base rsx? are they the same width? and same number of teeth and all? ive heard different things from different people so i just wanna make sure i get it done right the first time. and about the crv mount i have an eg with hasport mounts and a k20a2. my question is will any year crv mount work? thanks
