Hi. I always wanted to dyno every single modification on a k24. I started before christmas, and Im not finished yet. There is so much different stuff to test!
I had some questions I wanted to find an answer to:
•K24 oilpump & balancers, how many hp sits there?
•what mods is the most economical ones? I want to find which parts gives most "bang for the bucks".
•RSP, RRC & RBC, differences? But what is the differences with bigger TB?
•What is the gains if the RRC & RBC mani's are fully ported?
•bigger TB, when? What size?
•e85?
•Oem Honda cams, but which ones? K24a2, k20a2, JDM k20A or k20z? Which on exhaust and which on the intakeside?
•higher CR?
•ported head?
Well, Im not there yet, and some will I proberbly never find the answer on. There is some stuff that I keep simple and free flowing, like the exhaust. Started with stock CL9 dual exhaust anf recently I switched to a custom 3". Im not gonna try a smaller one. No need for that, have seen it on the dyno time after time, 3" always provide the best results. If you think its too loud, then think about 3 BIG silencers
(hatchbacks proberbly dont have the space for those..)
Airfilter was stock in the beginning, now its K-tuned 3" Cold air for EG/DC2 with velocitystack (seen great results before with that one too).
183hk@199nm, STOCK (146whp)
191hk@209nm, Hondata Flashpro & quick tuning
195hk@213nm, as above + Spark plugs
199hk@219nm, as above + K-tuned 3"airfilter w Velocitystack. (165whp)
197hk@220nm, as above + 72mm TB & portmatched entry in the manifold.
210hk@225nm, as above but with oem TB + RSP-mani
213hk@232nm, as above + no cat
218hk@237nm, as above + k20a2 oilpump
220hk@240nm, as above + 50 VTC-gear + 72mm TB
231hk@252nm, as above + Header PLM 4-2-1 (195whp)
231hk@252nm, as above + 3"exhast (need to go back to this and investigate)
241hk@253nm, as above + RRC mani (stock mani and with 72mm TB, so there is a big schart edge for the air to pass in the entry of RRC)(need to port the entry)
Have gone from 146whp to 202-203whp! Thats 57whp!!!
http://www.hondaklubben.com/forum/download/file.php?id=6490&mode=view
-green line is STOCK
-red is with header and 3"exhaust
-blue is with RRC
•e85?
•higher CR?
•ported head?
-blue is with RRC
