Wide tire size
2.2K views 17 replies 5 participants last post by  zotex
#1 ·
What is the widest tire size you can use on an EG hatch?
I saw a thread in the boost section where someone was running a 235/60/15. Some people have told me that 225mm wide tires will rub. I am trying to run the widest tire I can without rubbing problems and the smallest speedo variation possible.
I was thinking something like a 235/50/16 or maybe a 225mm wide tire. Something from BFG if possible.
Any suggestions?
#3 ·
PbnJ said:
depends on the width and offset of your wheels as well as what type of driving you will be doing.
http://www.miata.net/garage/tirecalc.html
http://gs.tolan-hoechst.com/tirecalc.htm
use the above to find the best combination for your application.
pj
I know that the tire size I am looking at will not throw the speedo off by more than 5mph. The width of the wheel will be atleast 7 inches. I'm thinking the offset would be a commonly seen offset for an EG hatch.
Driving style is drag..but the car will be a daily driver.
#4 ·
get some 225 for daily driver and 255 for drag
#5 ·
I run 215/45/16 on my hatch (EK) for road racing... I thought I was going to be assed out with the new Azenis, but Falken just released a 215 and a 225 to compliment the 205.
I think the 225 was a 225/50/16, but I am not sure what type of rims you want to run 15 or 16. I love my 16's and I love my Azenis...
#6 ·
Where did you find 225/50/16 in Azenis? I haven't been able to find them.
The only thing I don't like about Azenis is that they are quite heavy.
#7 ·
I saw them advertised in the new Super Street, the one with the 850hp S2 on the front...
I will see if I can find someone who sells them.
They are a great road race tire. When i let the instructor at my last track event drive my car he was surprised, he said the car felt just like his car which was riding on R comps... the matching 32mm sways may have made a little difference...
#8 ·
#9 ·
I would want to run a 225/50R15 with that setup since you get a bigger contact patch which is always good. Alot of people have said that a 225 width tire will rub, in which case i would just go with a 205/50R15.
Do you guys a 225 width tire will rub???
-Jalal
#10 ·
My 215/45/16's rub slightly at full lock, and they rubbed on my fenders a little till I rolled them...
#12 ·
Rubbed in the front or the back? I had my RSX-S fenders rolled for the wheel/tire combo I had on it and I don't know if I want to do it to this one. I was going to get the tires you are talking about wrapped around a set of Rota Circuit 8's. Best setup I could think of since I can't find any STICKY 225mm wide tires that fit a 16" wheel.
#13 ·
Anyone know what offset wheel I should get?
I am getting 16" Rota Circuit 8's and I'm trying to run a 225/45/16 BFG drag radials.
#14 ·
They rubbed in the front and teh back. But just a little and only when i hit a bump or something, they only rubbed on the outside of the tire kind on the sidewall. The front barely rub at full lock, I have a dime sized spot on the inside of the tire well where it rubbed off the lining at full lock.
I don't think you are going to be able to get away with anything really big without a little rolling of teh fenders..
#15 ·
If I can get away with 225mm wide tires with a certain offset wheel and rolled fenders then I don't mind. Any idea what offset I would need? I don't even know the average offset that people put on EG's. I had an RSX-S and I'm new to the honda world.
#16 ·
I think my K1's are +40 or +44mm. i think have seen +35 up to +45 i can't rememebr anything bigger than that.
I went through all of this about a year ago when I did my 5 lug swap. I think anything in the +40's would be alright, but don't just listen to me i am just going off of my memory which is not all that great...
#17 ·
#18 ·
I decided on 225/50/15 BFG Drag Radials in the front. They came in today. Once I get the wheels in and the swap done I'll be able to let everyone that may ask this question in the future know the answer to it. :dance:
