21 - 40 of 113 Posts
so lets say you have a bare k20 head and a complete k24 head.. is it possible to take all sensors off the 24 head and use them in the type s head?? if you would it make life easier if you were to use the k24 wire harness also since it will plug right up the the senors???
Discussion starter · #23 ·
I want to say yes, But I am not 100% sure. I'd say I'm 90% sure it not only has been done but works.
Added sensors from 06-7 Civic SI
Sensors/Valve Assemblys:
-Knock Sensor
Accord 04-07 Knock Sensor P/N: - 30530-PPL-A01
Civic 03-05 Knock Sensor P/N: - 30530-PPL-A01
CRV 03-07 Knock Sensor P/N: - 30530-PPL-A01
Element 03-07 Knock Sensor P/n: - 30530-PPL-A01
TSX 04-07 Knock Sensor P/N: - 30530-PPL-A01
RSX 02-06 Knock Sensor P/N: - 30530-PPL-A01
RSX-S 02-06 Knock Sensor P/N: - 30530-PRB-A01
Civic Si 06-07 Knock Sensor P/N: - 30530-PRC-003
-Crank Position Sensor
Accord 03-07 Crank Position Sensor P/N: - 37500-RAA-A01
Element 03-07 Crank Position Sensor P/N: - 37500-RAA-A01
TSX 04-07 Crank Position Sensor P/N: - 37500-RAA-A01
CRV 02-07 Crank Position Sensor P/N: - 37500-PNB-003
Civic 03-07 Crank Position Sensor P/N: - 37500-PNB-003
RSX-S 02-06 Crank Position Sensor P/N: - 37500-PNB-003
RSX 02-06 Crank Position Sensor P/N: - 37500-PNB-003
Civic Si 06-07 Crank Position Sensor P/N: - 37500-PNB-003
-Camshaft TDC sensor
Accord 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
CRV 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
Civic 02-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
Element 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
RSX 02-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
RSX-S 02-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
TSX 04-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
Civic Si 06-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
-MAP Sensor
Accord 03-04 MAP Sensor P/N: - 37830-PGK-A01
CRV 02-04 MAP Sensor P/N: - 37830-PGK-A01
Civic 01-05 MAP Sensor P/N: - 37830-PGK-A01
RSX 02-04 MAP Sensor P/N: - 37830-PGK-A01
RSX-S 02-04 MAP Sensor P/N: - 37830-PGK-A01
TSX 04-07 MAP Sensor P/N: - 37830-PGK-A01
Civic Si 06-07 MAP Sensor P/N: - 37830-PNC-003
-Water Temp. Sensor
Accord 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
CRV 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
Civic 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
Element 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
RSX 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
RSX-S 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
TSX 04-07 Water Temp. Sensor P/N: - 37870-PNA-003
Civic Si 06-07 Water Temp. Sensor P/N: - 37870-PNA-003
-VTC Spool valve assembly
Accord 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
CRV 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
Civic 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
Element 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
RSX 02-06 VTC Spool Assembly P/N: - 15810-RAA-A01
RSX-S 02-06 VTC Spool Assembly P/N: - 15810-PRB-A01
TSX 04-05 VTC Spool Assembly P/N: - 15810-PRB-A01 & 15810-PRB-A03
Civic Si 06-07 VTC Spool Assembly P/N: - 15810-PRB-A03
-VTC Oil Control Valve Assembly
Accord 03-07 VTC Oil Control Assembly P/N: - 15830-RAA-A01
Element 03-07 VTC Oil Control Assembly P/N: - 15830-RAA-A01
CRV 03-05 VTC Oil Control Assembly P/N: - 15830-PNC-003
Civic 03-05 VTC Oil Control Assembly P/N: - 15830-PNC-003
RSX-S 02-04 VTC Oil Control Assembly P/N: - 15830-PNC-003
RSX 02-04 VTC Oil Control Assembly P/N: - 15830-PNC-003
TSX 04-07 VTC Oil Control Assembly P/N: - 15830-RBB-003
RSX 05-06 VTC Oil Control Assembly P/N: - 15830-RBB-003
Civic Si 06-07 VTC Oil Control Assembly P/N: - 15830-RBB-003
Discussion starter · #27 ·
Nice! Added to the list. Credited you on the first page. :up:
Discussion starter · #30 ·
They're the same, the picture makes them look diffrent because they're mounted on a 45 degree angle on the cylinder head.
i'm in the same boat, i think u can, dont see y, but would the harness plug up to the rsx-s 03 ecu??
Discussion starter · #32 ·
Updated, Added Timing Chain Tensioners.
-Froth
Discussion starter · #35 ·
I have the K24A1 and K20A2 combination myself, and that is correct. The only sensor that needs to be replaced is the Knock sensor.
-Froth
I'm wondering if I need to swap out my knock sensor. I have a 06 Si engine. Noticed the part number was 30530-PRC-003... The PRC part is making me think it's the same knock sensor as the one found on the K20A (DC5 ITR) engine.
And while I'm asking questions, I take it that the VTC Spool valve assembly found on the 06 Civic Si (15810-PRB-A03) is interchangable with the 15810-PRB-A01 since it's listed as an alternative for the TSX?
-Timing Chain Tensioner
02-07 CRV - 14510-PNA-003 (K24A1 and K24Z1)
03-07 Accord - 14510-PNA-003 (K24A4 and K24A8)
02-06 RSX Base - 14510-PNA-003 (K20A3)
03-07 Element - 14510-RAA-A01 (K24A4)
02-06 RSX-S - 14510-PRB-A01 (K20A2 and K20Z1)
04-07 TSX - 14510-PRB-A01 (K24A2)
06-07 Civic Si - 14510-PRB-A01 (K20Z3)
is there a major difference between those 2 ?
would it be better to use the PRB timing chain tensioner in a k24/k20 swap ?
better oil pressure, reliability or i dont know ?
if they all use the prb in the "real" vtec setups is it a must in a k24/k20 ?
anyone using k24 one without problems?
thanks
Discussion starter · #38 ·
I have the stock CRV tensioner in my K24A1/K20A2 frank setup with no issues whatsoever.
-Froth
all right
so what ill do
is take my k20a2 timing chian tensioner put it in my k24/k20 and put the k24 tensioner on the k20 block
jsut to be safe since itll be a 330whp setup i want the best
and the k20 block wont see the difference if you say you use the k24 tensioner without issues
good idea?
btw ive just learned that i needed to change the knock sensor and crank sensor to fit my wiring... glad i readed that before selling the k20 block :p
for the knock sensor its ok
but for the crank sensor im still confused...
cause my friend builded a few and he says that the k24 sensor fits on the k20 wiring harness
whats the differences between them ?
length? pinout? connector?
cause i have one that came with my k24 chain case cover and another one on my k20 chain case
wich one should i use
cause if the k24 one is longer i could not use the k20 one ....:confused:
quick question about cam (tdc) sensor oem part # 37510-PNB-003
according to this you need 2 of them (but they look completely different in the diagram) - part #6
link to page
http://www.acuraoemparts.com/delray...atcgry3=3DR+TYPE-S&catcgry4=KA6MT&catcgry5=CYLINDER+HEAD&ListAll=All&vinsrch=no
In relation to this, I noticed that the 06 Civic Si uses two different camshaft TDC sensors...
Noticed this when trying to move my wiring from my blown RSX block to my 06 Civic Si block.
Civic Si 06-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 (exhaust), 37510-RAA-A01 (intake)
