I've been gathering dimensions for wheel bearings, hubs and knuckles. I haven't started on the knuckles yet so this is still in progress.
Measurements are all in millimeters.
ID = Inner Diameter, OD = Outer Diameter, IW = Inner Width, OW = Outer Width (assume same as inner width unless stated)
Bearings:
Bearings:
Code:
Honda Bearing ID OD IW OW Reference Examples
44300-S04-004 38 73 40 40 [url]http://www.herkules.si/index.php?productID=19058[/url] [url]http://www.hi-pro.com.cn/adminmain/Up/uplodaffils/200743066367893.pdf[/url], Del Sol S/Si
44300-S04-008 38 73 40 [url]http://www.herkules.si/index.php?productID=19058[/url], Del Sol S/Si
44300-S04-A02 43 79 41 38 [url]http://www.hi-pro.com.cn/adminmain/Up/uplodaffils/200743066367893.pdf[/url], "Del Sol Si-ABS/VTEC, 95-00 Civic"
44300-S47-008 45 84 40 [url]http://www.conceptautosport.co.uk/products.php?plid=m8b27s133p364[/url], "CRV, Prelude, S2000, JDM ITR?"
44300-S5A-004 43 79 [url]http://www.k20a.org/forum/showthread.php?t=33724[/url], 97-01 Integra
44300-S5A-008 43 79 Same as 44300-S5A-004, "01-05 Civic, 2001 Integra"
44300-S84-A02 45 84 [url]http://www.k20a.org/forum/showthread.php?t=33724[/url], "Accord, CL, TL, RSX/RSX-S"
44300-SB2-900M 38 72 40 [url]http://www.hye.com.tw/wheelbearingfront.htm[/url]
44300-SB2-963 38 72 40 [url]http://www.herkules.si/index.php?productID=19054[/url] [url]http://www.hye.com.tw/wheelbearingfront.htm[/url]
44300-SB2-964 38 72 40 [url]http://www.herkules.si/index.php?productID=19054,EF?[/url]
44300-SB3-004 38 73 40 40 [url]http://www.google.com/search?q=cache:NDPrG9b5ekMJ:www.autopartes.biz/autoparts/bearings/wheelbearings.asp+%2244300-SR3-004%22&hl=en&ct=clnk&cd=11&gl=ca[/url]
44300-SB3-004 38 73 40 [url]http://www.hye.com.tw/wheelbearingfront.htm[/url]
44300-SE0-003 40 76 41 38 [url]http://www.hye.com.tw/wheelbearingfront.htm[/url]
44300-SE0-004 40 76 41 38 [url]http://www.hye.com.tw/wheelbearingfront.htm[/url]
44300-SG0-000 44 84 [url]http://www.alibaba.com/product-gs/319909672/513052_44300_SG0_000_44300_SG0.html[/url]
44300-SG0-008 44 84 [url]http://www.alibaba.com/product-gs/319909672/513052_44300_SG0_000_44300_SG0.html[/url]
44300-SR3-004 38 73 40 40 [url]http://www.google.com/search?q=cache:NDPrG9b5ekMJ:www.autopartes.biz/autoparts/bearings/wheelbearings.asp+%2244300-SR3-004%22&hl=en&ct=clnk&cd=11&gl=ca[/url] [url]http://www.hye.com.tw/wheelbearingfront.htm[/url]
44300-SR3-008 38 73 40 Same as 44300-SR3-004
44300-SR3-A00 43 79 [url]http://www.k20a.org/forum/showthread.php?t=33724[/url],Not found
44300-SR3-A02 43 79 41 38 [url]http://www.herkules.si/index.php?productID=19059[/url] [url]http://www.conceptautosport.co.uk/products.php?plid=m6b15s48p126[/url] [url]http://www.hye.com.tw/wheelbearingfront.htm[/url]
44300-SR3-A04 43 79 41 [url]http://www.conceptautosport.co.uk/products.php?plid=m6b15s48p126[/url]
44300-SS0-014 44 84 42 [url]http://www.alibaba.com/product-gs/334250162/auto_bearing_DAC44840042_40_VKBA3302_.html[/url]
44300-SS0-018 44 84 [url]http://www.alibaba.com/product-gs/319909672/513052_44300_SG0_000_44300_SG0.html[/url]
90305-691-010 38 72 40 [url]http://www.herkules.si/index.php?productID=19054[/url]
91055-SB2-960 38 72 40 [url]http://www.herkules.si/index.php?productID=19054[/url]
