1,281 - 1,300 of 1,675 Posts
If your rbc is already ported, I honestly don’t think a stock RRC will outperform it by much if at all. The 2.2 should be enough to get you to 250 whp.
Yeah my tuner said the gain will be very minimal if at all. I'm just going to enjoy the setup for what it is right now, maybe upgrade the Cai to a 3.5 inch eventually. I'm very tempted to boost my car but it is my daily so I want to keep it reliable.
It depends on the header and intake setup. Member Lotus had an case with his 2.2 stroker engine, where the (ported) RRC IM came out less performant as the RBC IM. Here a short intake and a 4-1 header was used. When member katman tested a unported only opened 70 mm TB RRC IM it came out better almost 10 whp then the RBC (ported and unported), he used an AEM CAI which is a long intake piping with filter position in the lower bumper section. I am not sure about the details, European IP's can't reach out the superstreetonline.com article without tricks.
I think that is a good idea. 240whp in a rsx should be pretty fun, you could always make it lighter or get more traction to go faster.
Definitely.
The DC 3.5 OG series cams are short duration high lift cams, which does, depending on CR, a good job in a 86x86 engine. There was an engine tuned and built by Advanced Tuned Performance who made on a 86x86 engine, CR 12.5:1, H, E, stock head 292 flwhp/265 flwNm, which isn't bad (DynaPack). Link is lost, but I documented it here: (1) Drag Cartel 3.2's | Page 3 | Honda / Acura K20a K24a Engine Forum
Hi guys. I thought I'd share my Dyno results with everyone since I don't see many results with my setup and also to get some feedback.
The car is a 2004 Acura RSX Type S with the original k20a2 (150 000 miles approximately). The bottom end of the engine is completely stock, never been touched. The head has been built.
Mods:
-DC 2.2 Cams
-Supertech dual valve springs, seats, seals
-Supertech titanium retainers
-Arp head studs
-Fully ported RBC manifold
-Ktuned 72mm throttle body
-Injen 3 inch cold air intake
-Skunk2 alpha race header
-Ktuned 3 inch catback exhaust
-RDX Injectors
-1 step colder NGK plugs
Car was tuned on 94 with kpro v4 and made 241 whp and 166 torque. The tuner believes that the cams are able to make more power but the intake setup is restricting the air flow. I agree with him. What do you guys think of the results? Is it good power for the mods? Do you think I can break 250 pump gas with a similar setup (stock bottom end)?
My graph:
Very good power :) for the mods.
I have done 2 accords thats made similar power but with RSP heads on it. I will post their graphs in a bit with mods.
104293
-BC Stage 2 Cams
-RRC manifold
-J37 throttle body
-CP 90mm cold air intake
-Noise Boys header
-Steel Solutions 76 to 63 dual exit exhaust.This car use have a single exit 63mm that is the reason for the power difference on the overlay.
-RDX Injectors
-Road Tuned with Ktuner
Bother cars has different gearbox mods that is the reason for the speed differences in gears. Both also running max 27/28 degrees ignition and on pump stock sub assemblies.
Power is hardly raising past 7000 rpm with the BC stage 2 being a tad better in this regard-
I had the big torque bump at about 6000-6200. Your's hits earlier most likely due to the better exhaust manifold design compared to mine for a NA engine. The little bump at 6200 rpm is also visible in your graph. I would guess this is a resonance point (~4th harmonic, Markus?) of the RRC intake manifold. Mine was more pronounced likely due to the porting.
This kind of shows again that the RRC intake manifold has a focus on the mid range. Compared to the unequal length runner RBC manifold, you get more mid range, but torque increases more steeply before 6k and drops more pronounced past 6500 rpm. The RBC smooths out the torque curve trading off that 6k peak vs more torque before and after the mid range. The RBC feels much more smooth and not as flat at the top, at least on my K22. But dyno sheets posted here and elsewhere fit to that observation.
Hi guys,
I am preparing my future assembly following the blow of my k20 a few months ago.
K24a3 (stock) with head K20a2 (stock)
RBC ported by me / 70mm
70mm TB
3.5 "intake
Rcrew replica header
3 "inch exhaust
Dc5 fly
Lightweight crank pulley
The map will be in E85 (Very inexpensive here in France, not to mention the performance!)
I was thinking of 850cc fuel injectors but in the end I realize that 600cc ~ would be more than enough?
I'm annoyed because I usually get my injectors from Performance Fuel Injection, but they don't make 850cc anymore: /
I usually take (legit) Bosch injectors, because they are reliable and cheap, other brands are overpriced!
Thank's!
600cc/min injectors on e85 might just be enough depending on how high you rev that thing, just.
I‘d go for some ID725 or even ID1050x.
If you ever decide to forge the engine or go forced induction, you have a litte headroom the the latter.
PS time I can get my superethanol in France again. I live near the border, but getting fuel is not worth the trouble in the moment due to Covid restrictions. I run in my Prius since 2013 and also in my K20 Elise.
running big injectors on a single bank requires carefully matched injectors to pass emissions testing at idle and low duty cycles.
If this is of no concern to you, use whatever injector you think is suitable. Remember to set-up the voltage dependent dead times in the ECU for these injectors.
I have not found original data from Siemens so far, but only this:
Thanks again for the reply!
I still see that all this is very technical and does not depend only on cubage / cc and impedance!
I just found a US seller offering the Bosch (Legit) 1000cc at a very good price, I will choose reliability!
Stock K20a2
Rcrew header
2.5 inch exhaust with BC Muffler
Short ram Injen
K-pro tuned
210whp 149wtq:up:
mustang dyno.
Edit: Retuned with same mods+RBC made 218whp 148wtq:up: 🆙
what chassis is this set up in? So with My DC2 so far this closest setup I found to mine.
I'll probably hit roughly the same power area 210whp-240whp somewhere.
Wish I had your tuned map .kal to run my car and tune off of.
Why don't you take the ITR-CAI-H-E map Hondata is already offering? With an wideband you can run it for short time. Don't WOT it till dyno.
I had some injector issues now Im back at using map my question is are the ITR cams and Type-S Cams the same?
I maybe have to use the map just for daily cruise as I'm about to park for winter
The ITR cams have a slightly longer duration compared to PRB cams. I had to do a fair few map alterations, mainly fueling, on a very good k20a2 map used in the Elise to get it to run properly. OK, this also involved an RBC intake manifold. But the map even needed changes at low throttle settings.
I have the PRC cams too. I also have the exhaust cam from the 04-08 K24a2 on the shelve. I have heard a mixed bag of answers on mixing and matching PRC cams and K24a2 cams, I could install it if it was a proven good idea to do. I always viewed things as the PRC should be kept together vise versa.
Thank you..
I am bummed I have a set of Z1 PRC version cams and they have some risky spots on on them that are not worth running the risk of damaging the rockers. I have heard this story from multiple people over the past two decades that the longer duration is what makes the PRC cam work. In fact Honda never changed the cam profile for the FD2 CTR from the DC5 ITR PRC. However there are different PN#'s of the PRC floating around between the Euro R K20a, K20Z1, and the DC5 ITR.
The 04-05 K24a2 intake cam is 1 of the 5 cams that is an option in the CL7 Euro R K20a PN# 14110-RBB-000.
The DC5 ITR has 4 versions of the PRC intake cam one of them is PN# 14110-PRC-030 which is the K20Z1 intake cam, and it sells for $353.00. The rest of the ITR PRC cams cost $445-473 being there are three versions. PN# 14110-PRC-000, 14110-PRC-010, 14110-PRC-020. In the USA, they say the Z1 cams are discontinued, but they can be purchased from Japan for $353. for the intake cam and exhaust cam.
The DC5 ITR has two different VTC gears. One is $20 than the other that we know as the RBC (46T). The other is a PND VTC gear However the PND is not listed as "46T".
The Euro R has two versions of the balance shaft oil pump. " one is $586 PN# 15100-RAC-006 and the other $517 PN# 15100 RBC 016.
Have you thought about taking the cams in to be polished or will that not save it ?
