1,241 - 1,260 of 1,675 Posts
Popped the valve cover today. Good news is they are indeed DC 3.2 cams as confirmed by the manufacturer mark "Drag cartel 0032“. Guess the bad news is this tune is really wonky.
Well at least you’re not out the thousand bucks for those ! Sounds like you’re in for some gains as well. Usually 3.2 cams I would think would get you more in the 280 range if your intake and exhaust are adequate
That'd be nice. Just got done emailing Jeff from Evans Tuning, his assessment was much the same. Garbage tune. I'm going to see if he won't hook me up with an etune for it. Shame too the shop I took it to did great machine work and fabricated a really nice 4" short ram with v-stack and heat shield for me. Just not really the best at turning (to put it mildly) I guess. Live and learn.. Guess I'll take the $500 L and move on.
Well it sounds like you got a game plan at least and are on the path to getting it all squared away that’s lucky the tune didn’t blow your sh”! Up
Civic EM1 2000
Motor: k24a3 block / K20Z4 head DC5R Cams
Pistons NPR 12.5:1 , Forged rods.
k20a2 oil pump/crankshaft pulley/flywheel
PLM 4-2-1 and 3" exhaust.
Subaru WRX injectors 440cc.
RSP(fn2r) intake on stock TB ep3
dc5r trans Y2M3
fuel 100 RON
Hondata k-pro v2
Engine tuning on the road,did it myself. This week I signed up for a dyno, I think I can build a more interesting VTC map
In the meantime, I am attaching my Dragi measurement and the Virtual Dino graph that I did during the setup process.
102432
102430
102431
Hi guys,
Here I am back after having had a lot of things to take care of, next door!
I come here to share the new dyno made this Sunday.
As a reminder, the setup:
Ekk20
K20a2 145kkms Full Stock (From valve cover to oil pan :d )
HeaderRcrew like (Megan racing)
Exhaust 76mm (2 Simons)
RBC (70mm bored, not ported)
70TB
Intake velocity stack, 3" tube
FI 550cc
Flywheel Dc5
Crank Pulley Tegiwa
E85
We had as result last year:
36 ° C (Heatwave!) = 232.24hp / 214.3nm (2.5" exhaust)
Last dyno:
25.8°C = 254hp/231nm (3"exhaust)
Several things:
  • The 1st dyno was performed with OEM Honda rims (EP2 15 "> 9kg each) and the second with OZ Ultraleggera (15"> 5.9kg each)
  • It was really excessively hot on the day of the 1st dyno (Stifling!)
  • I don't know if the 1st dyno is well calibrated but the 2nd looks good! Just before the EK, a 1p Leon Cupra was passed (MAP, R8 coils, decat, 3" exhaust> 291hp, which seems quite correct for setup)
  • As specified, the 2nd dyno was carried out with the 3 "exhaust and that confirms what I had felt! Loss of torque at the bottom, but the car was going stronger afterwards!
What do you think of all this?
@LotusElise Hello, We can clearly see the different curve here!
Thanks for the cooooool update da_sherminator!
Much more realistic numbers for E85 and that engine setup. But there are still questions for me. The most pressing question is, why does the dyno measured power and torque curve stop at 7850 rpm. The torque still holds strong (which is not common for a RBC IM) so power would still climb. It doesn't look like a stock longblock setup with an RBC. It looks more like a stage 2 cam setup with an different IM. VTEC is pretty late for a 3" exhaust piping, but that could also be caused by the RCrew header copy. But most wondering point is why the heck the torque stands that long that high with just an stock setup and bolts on and why the curves stops when it still climbs. We still talk about a 86x86 engine, which easily revvs to 8500 rpm in a DD application.
[QUOTE = "LotusElise, post: 3312751, membre: 16822522"]
Merci pour la mise à jour cooooool da_sherminator !
Des chiffres beaucoup plus réalistes pour E85 et cette configuration de moteur. Mais il y a encore des questions pour moi. La question la plus urgente est de savoir pourquoi la courbe de puissance et de couple mesurée par le dynamomètre s'arrête à 7850 tr / min. Le couple reste fort (ce qui n'est pas courant pour un RBC IM), donc la puissance grimperait toujours. Cela ne ressemble pas à une configuration de stock long block avec un RBC. Cela ressemble plus à une configuration de caméra de niveau 2 avec un IM différent. VTEC est assez tard pour une tuyauterie d'échappement de 3 ", mais cela pourrait également être causé par la copie de l'en-tête RCrew. Mais le point le plus surprenant est de savoir pourquoi le couple est aussi long que haut avec juste une configuration d'origine et des boulons et pourquoi les courbes s'arrête quand il grimpe encore.On parle toujours d'un moteur 86x86, qui tourne facilement à 8500 tr / min dans une application DD.
[/CITATION]
I understand, I couldn't answer these questions! However, I can simply confirm the configuration of my block at 100%;)
And as far as the map goes, of course it hasn't changed since the last dyno.
Aren’t the hp and tq supposed to cross at 5250rpm or is that only on a wheel based dyno? The hp looks very linear on his graph am I reading correctly it’s making almost 200ft lbs on a 86x86 ?
[/CITATION]
My french isn't bad according a translator 😜.
Thanks for the hint 😉.
Mmmmhhh...the shape is different, you confirmed it yourself in post #1274, normally also the VE must be different. This need a hardware difference or different tune. Did you change the head hardware?
The crossing engine speed is depended on the units we talk about:
  • 5255 rpm if hp and lbft (Imperial field, 1 kW = 1.34 hp)
  • 7126 rpm if hp and Nm (mix of hp based in imperial correlation of 1 kW = 1.34 hp, 1 lbft = 1.356 Nm)
  • 7021 rpm if PS and Nm (according DIN or EN Norm)
are used. One should be aware of different scales which are used here. With different scales you can have the crossing point where ever you want.
Follow up to previous post...
Just finished retuning with @LotusElise etune servicea few days ago. Here's my plug / review after we fixed a rather long list of issues the tune I got locally from MRD had, (see earlier post from @LotusElise) including that tune running incredibly rich..like 18-19 mpg rich...like Jeff Bezos rich. We did some adjusting and testing based off street logs, then I opted to rent a dyno for a few hours and have him finish the WOT high end tuning there. Dyno picture below of the last two pulls, same engine/set up but dyno we rented was a dyno jet where the previous pic I posted was off a higher reading Mustang Dyno.
Lost a bit of power in the mid-range due to limiting max VTC to 40 degrees per Drag Cartel recommendations (where before it was an unsafe 50 degree max/no limit) which bumped the vtec engagement to 4500 from 4000. The drive is night and day though, even if little or no power was picked up at the top end. The power band and drive quality is amazingly smooth as is the vtec transition now. Markus was a pleasure to work with, was extremely thorough in setting up the tune and going into great detail of the reasoning behind aspects of the tune, I actually learned quiet a lot through this process. Would recommend if you're looking for an etuner that really knows their stuff.
Motor: k24 block /w k20 head Stock port, decked/trued 87.5mm Bore with wiseco 11.1:1 pistons, balanced crank, manley rods. k20a2 oil pump.
Ktuned Header-Ktuned 3"oval exhaust.
DC 3.2 Street Cams /w upgrade valvetrain.
FIC 525CC injectors.
RBC intake on stock TB with custom 4" short ram
Stock a2 trans with the stock 4.3 final.
102567
Nice ! Wonder what it would do with a big manifold and tb combo. I bet it feels great now that everything is cleaned up !
Like I said, night and day compared to the last tune much more smooth. The engine definitely likes air though, had great scavenging effect. I'm sure a bigger Tb, port job maybe some head work would make good gains. Maybe down the road, next upgrades are suspension and transmission really needs an lsd and some better gearing.
I have the same trans type s with 4.3. But have yet to drive it. My last k swap had a base 5 speed as well. Ive seen a few saying the 4.7 trans are way too short without the tsx 6th.do you find it’s not accelerating quick enough with the 4.3?
Thanks for the kind feedback and very good team work Brosome. For me it was a pleasure to work with you :). I really appreciate it.
The dyno time window was really challenging, as 24 different maps had to be optimized and overlaid optimally for final tune: WOT VTC, WOT fuel, WOT ignition timing. Finally we made 32 runs and there is still fine tune work of fuel and ign. timing left open. Beside that I had no access to the dyno result screen, only th written chat information of the driver, which had no headset. Sometimes I was asking the same question in the chat 7-8 times before the driver saw it on the screen and reacted, but hey, we made it :).
A made a comparison of both dyno results to see what have changed in the torque/power curve (s. below).
102568
As the results were made on different dynos, I've tried to do a bit more fair comparison to show Brosome what was the outcome for him. At around 6500 rpm there was a calibration point were both, VTC and ign. timing of both calibrations was exact the same, just fuel was +20 % more rich at the MRD tune. Normally at lambda around 0.92 you find the optimal flame speed with the 87x99 combustion chamber, the 86x86 tend to like it a bit richer. Here with the MRD tune we talk about a lambda of 0.68, which is far from fastest flame speed, so torque can be assumed to be lower. But anyway let us assume to have the same torque at 6500 rpm and use offset to correct the complete curves. The offset of torque at 6500 rpm of the MR to MRD tune is 6.8 wftlb's. Using the offset for the complete curve MR +6.8 wftlb, gives us following result.
102571
For me this picture makes much more sense regarding it is the same engine and fuel, just a different tune with a 40° VTC limitation instead of a 50° VTC bandwidth.
Low speed cam:
The low speed cam in the MRD tune was set to 50° VTC. This is far from optimum, as too much exhaust gas stay in the comb. chamber, lowering both, VE and combustion velocity. The result is less torque almost everywhere below VTEC compared to the MR tune.
VTEC and High speed cam:
With the capability of 50° VTC an earlier VTEC is possible as high speed cam loves scavenging with this setup. With the 40° limitation only 4500 rpm VTEC was possible. Further on the 50° VTC is really missed in the MR tune, less torque everywhere up to the point where both VTC are the same, which is around 6450 rpm. The 40° limitation comes from the DC 3.2 cams and the Wiseco 11.1:1 piston, which were not clayed, so we had to follow the recommendation of DC. Better safe then sorry, even if it cost finest ponies! Beyond 6450 rpm VTC is below 40°, so both tuners are free to choose the optimum. MRD did steeply decrease VTC, while the engine loves to have more. I followed the engine and let it down only to 30°@8500 rpm, which tells us this particular engine has an amazing scavenging efficiency! Interesting, the engine didn't like more ign. advance at high speed cam, which was finally around at 25-26°. I am still thinking about that fact. Anyway, I love this setup and I learned alot about the K-series engines again. Thanks for that chance Brosome!
Observations and interesting hints:
  • we had a massive low load false knock issue, about 500 knock counts in 20 min commute. We've investigated this, reduced IAT by 15 °C, retarded timing by 5° in the knock areas and saw no single change in that. Beside that we checked for vibrating parts on the engine (none), we checked for piston slapping (none), we changed the knock sensor (no effect beside better signal quality), we checked leakdown test (fine), compression test (fine), we changed oil to lower knock likeability (no effect), we checked spark plugs and changed them (no effect), we clumped the low pressure blowby hose (no effect). So almost every knock cause was checked, maybe we missed something? What I observed was every time VTC rotates over 10°-30° there where 3-12 knock counts, also under higher load conditions from 1800-4000 rpm we saw massive counts added. I assume some of the noise came from the timing chain under relaxing and tensioning transition conditions on the intake side caused by the camshafts. The other one, which is bounded to engine speed and load and which can't be affected by ign. timing, maybe from valvetrain or pistons slapping. I am not sure about it, the video didn't make it clear to me. Maybe someone out there know some causes?
  • I've made an eco tune for low speed cam, which saved about 20 % fuel from 1700-4000 rpm and idle to below WOT conditions. We agreed on to keep the tune as did come from the dyno. But the fact that about 20 % less fuel would be possible to the MRD tune of the low speed cam and low to higher load conditions was really surprising to me. This engine would definitive earn the greenhouse gas saving AWARD from the EPA with the MR tune in total...LOL :D!
The only thing I would still change, we worked on that point in some iterations, is the intake routing. Here there is some potential left beside some further bolt's on changes. The first would give a cooler and bigger distance to the knock margin, the later is definitely on intake side as this engine likes to breath more. She is hungry, not only for FUEL, also for AIR 😄!
Edit: the best compliment was made by Brosome's wife, which commented according him during driving, it would feel to be different, much better... . If a female remarks this, it must be really a significant and positve change. Wife's are the honest and most neutral tuning rating instances, as they see the money flow, going into the car, more critical then the husband does it 😉!
Low speed cam:
Sounds like you did some very nice work 👍 I do have a question though, when you say “knock count “ was being recorded, is that actually a knock inside the engine with metal parts touching (crank, bearings, rods) or is it from the spark plugs firing improperly according to the fuel and air coming in ? I’ve heard of “spark knock” but don’t fully understand or know if that term is proper.
...“knock count “ was being recorded, is that actually a knock inside the engine with metal parts touching (crank, bearings, rods) or is it from the spark plugs firing improperly according to the fuel and air coming in ? I’ve heard of “spark knock” but don’t fully understand or know if that term is proper.
Good question. The meaning of "knock count" here is KPro Manager SW counts the events, which are rated by ECU as an Knock Event. The parameter in KPro Manager is called "Knock Count".
Background:
The Honda Anti-Knock-System is very simple. It consists out of a "ear" the knock sensor, the wiring to the hardware listening to the knock sensor signal and the SW which compares the signal to a engine speed and load related map of maximum signal amplitude. If the SW see an specific for engine speed and load exceeding amplitude it interprets it as knock. So the only thing preventing this system from listening a false knock is the specification of the knock sensor. If this part has not the specified frequency sensitivity (resonance tuned), then wrong interpretation is most likely. So use only OEM sensors or the exact copy of it. Otherwise when the knock source get changed with turbo, header, higher VE, different timings and so on the signal amplitude get changed while the thresholds get not. In that case you get a mismatch of both and wrong interpretation is the consequence. Anyway, any change of HW or SW on the engine affects the reliability of that system.
The knock events we saw were independent from the thermal knock, which is a pressure oscillation in the chamber with supersonic speed and huge pressure amplitudes of up to 1000+ bar peak. It get caused by self ignition of the mixture which is not below the flame front but in front of it. In a rough simplification, think of two waves running to each other and heat each other with some massive reflection, super-positioning and a lot of fun to combust much more faster. If such a 100-1000+ bar peak pressure hits the wall and lose some of it's energy at the wall during reflection it makes a noise like you hear when you collapse these air chamber containing foils which are used for sheltering products during shipping. I mean the small (around 8-10 mm ID) circular air chamber foils. If you press them the foils get stretched until it breaks and make that little hard explosion noise. This sounds a bit like knocking.
With the above mentioned Background now you can imagine false knock is a signal of the knock sensor, which let it exceed the threshold, but is not caused by combustion, it is maybe caused by an oscillating plate, a loose timing chain, a hard cam lobe or what so ever. False knock can have any source which in amplitude and frequency looks similar to the knock amplitude and frequency. The frequency we speak about has 6.7-6.5 kHz with the 86-90 mm bore size. A rattling timing chain is a good candidate to have such frequency and high enough amplitude in its noise spectra.
I am not sure about the English term "spark knock". If it means thermal knock or knock caused within the combustion, then I would be ok with that. But it is not very likely to have a knock event at the spark plug, almost impossible. Knock happens always in the so called end gas, the mixture in beyond the flame front, never within the flame front. This does not mean spark plugs don't get affected by knock events, they do, the pressure waves running in all directions up and down destroy everything on there way and where the peak touches the wall it increases highly the heat transfer by factors. So melting, pitting is all included. But this has nothing to do with the knock source, only the consequences.
I saw many data about knock, pre-ignition, running knock, glowing knock and all that kind of in engine damages, papers and measurements during my career. These are the most dangerous and best investigated but less understood combustion events when it comes to IC engines. Some of them like thermal knock can be handled easily with some know how and with an good detection system. The issue is, no single detection system of any OEM is safe enough to interpret knock right after the source system was changed. There is no general rule, it is always an adapted listening with simple up to complex mathematical analyse systems which say yes or no to a signal. So, never expect an modified system with the stock knock detection system to be safe. You need always to hear yourself if knock signal is a yes or no and tune the knock interpreation yourself. My issue as tuner is, none of the customers pays for this as this takes a longer road down and need onsite work with special equipment, from simple DIY DET cans, which work very good if you know what to listen to, up to 10-100k detection systems, which measure the in-cylinder conditions (via pressure, light reflection, frequency spectra analysis and so on).
I worked 9 years for an OEM engine development on test bench from single cylinder up to full sized engine, field applications and in the pre-development process of the combustion process design. No single detection system makes an engine safe, because all of them are reacting systems, none of them are predictive. Honda tried to do so with there K.Control (KPro parameter) calculation, which uses ign. timings for longer period of times when detecting knock, its a sort of fuel sensing system. But it works very conservatively. Nothing good for racing or weekend worriers. It can calm the engine down so that you mean you drive a half size engine when maximum conditions are reached.
If you run an engine like Brosome does it with stock knock logic activated, you cut the power output by up to 25 %, reduce the mpg massively and get a weird and less cross sounding engine finally. Therefore we investigated the if those knock events will get a yes or no. Our strategy after the analysis is frequent observation of spark plugs, retarded ign. timing map, aggressiv IAT bounded ign. timing retard and some other stuff and with stock knock logic off. Unfortunately the driver at the dyno wasn't able to differentiate knock and noise with the DÈT can. As I said, you need to know what to listen too. Honda engines makes a lot of noise, it need will and experience to differentiate knock from noise. That guy wasn't willing to listen, he was more on his phone as on the DET can. Some noise I was able to hear via driver laptop and Skype, at least his many phone calls (not with me) :cool:. So no data from that side, therefore the conservative ign. timing tuning.
