701 - 720 of 1,675 Posts
Motor: k20a2
Header: Hytec
Cams: ips kme / skunk 2 valves super tech valvetrain
Intake: k tuned
exhaust: skunk 2 3"
Tranny: stock a2
Misc Mods: rbc bored and port matched to 70mm, 70mm throttle body.
262whp
171tq.
Tuned on aem ems
Next is high comp pistons/rods. Or k24 bottom end with pistons/rods.
Hoping for 280-300whp
What type of dyno?
DynoJet??
-Marquis
-KMOD
Motor: K20z1
Block: Wiseco 12:5:1 86.5mm bore
BP Pro I-beam Rods
Head: Skunk2 High Compression Flat Valves
Skunk2 Dual Springs and Retainers
Skunk2 Stage 2 Camshafts
Skunk2 exhaust cam gear
Skunk2 Intake manifold 76mm bore
Golden Eagle Polished Fuel Rail
RC 550cc fuel injectors
Injen tech CAI
DC Headers
Greddy EVO2 exhaust
k20z3 LSD tranny
kpro
Sorry going off topic here but how much power do you guys think this setup should make?
1993 Honda Civic Ex
2004 K20a2 W/ Quaife LSD
KPRO
Custom 4-3.5-3" Intake with BPI Stack and 6" K&N Air Filter
RCrew Header
Kteller 3" Exhaust w/14" Resonator and Magnaflow Muffler
Drag Cartel 2.2 Endurance Cams
Supertech Valve Springs,Retainers,Seats
HR 74mm Throttle Body
Port-matched RBC IM
Hondata IMG
RDX Injectors w/ clips
Golden Eagle Fuel Rail
AEM Fuel Pressure Regulator w/ SS Braided Lines
255LPH Walbro Fuel Pump
This setup in my EG hatch
Motor: k24A4 block with 04 TSX rods,pistons and a stock k20Z1 head
Header: R crew
Cams: stock
Intake: RBC manifold with HR 74MM TB
Exhaust: 3' custom
Tranny: EP3 5 speed
Misc mods: Kpro
Track info: not known yet....
WHP: 236 TQ: 190
i can finally contribute.
UKDM K24A3
258.2 bhp around 220/230whp
206.5 lbft
not sure what the dyno was i cant remember.
custom 3" cold air intake with K&N
J35 64mm throttle body
RRC intake manifold
P2R thermal intake manifold and throttle body gaskets
06+ TSX intake camshaft
pinned 40* degree VTC gear
WeaponR exhaust manifold
200 cell high flow cat
skunk2 cat back.
287whp 195wtq
KMOD Performance Stg.3 K24 Engine
87.5mm x 99mm
84mm TB
GATO IM
K20a2 Cyl. Head
BC Stg.3 Cams
Supertech Valvesprings
Supertech 12.5:1 Pistons
Eagle Rods
KMOD Oil Pump
ASP Race Header
3in Exhaust
Only a few pulls on this set-up. Lots of Air/Fuel, VTC, & Ignition tuning still left to do.
-Marquis
-KMOD
Are eagle rods all that you use for your builds? I've seen them on most K motors you build. You dont use any other H beams rods?
We use Eagle rods on our stg. 2 & 3 Engines & BC Lightweight rods on our stg.4 Engines. Our engines can be built to your request, but changing parts may affect the price. You have your choice of Eagle, BC, K1, Manley, Carrillo, Crower, or GRP Aluminum rods.
These upgraded rods are all available options on our website.
-Marquis
-KMOD
-Marquis
-KMOD
Whats the rev limit on the engines with the manley & eagle H beam rods and the BC lightweight rods?
Guess you have had success with all these, just use use eagle cus they're cheaper than the rest or am I wrong?
We have used the Eagle, & BC lightweight rods up thru 10,000 rpm w/o issue.
-Marquis
-KMOD
ek hatch original owner
02 k20a2 stock longblock
mfactory lsd 4.3 final drive
act streetlite flywheel??? it came with the swap
3.5 bpi velocity stack
3.5 custom cai thermal wrapped
HR 70mm throttle body and thermal gasket
70mm rbc manifold hondata img
rdx injectors
R-crew header
3" exhaust magnaflow muffler
K-pro
tuner Matt Shue
Dynojet 233/166 corrected
Just picked up a set of Kelford 179a's. Will post results after I receive, install, tune, and dyno them.
287whp 195wtq
87.5mm x 99mm
84mm TB
GATO IM
K20a2 Cyl. Head
BC Stg.3 Cams
Eagle Rods
KMOD Oil Pump
ASP Race Header
3in Exhaust
-Marquis
-KMOD
Nice Marquis!!! I should be done with my RSX k24/20 all motor build within a few months, if everything goes well on dyno, I will post my results on here.
Thanks, Def let us know what you end up putting down.
-Marquis
-KMOD
Motor: K20Z3
Header: K Tuned Ram Horn (Gen 1)
Cams: stock
Intake: Karcepts
exhaust: K tuned 3" cat with Skunk 2 76mm catback
Tranny: Z3 w/ 5.062
Misc Mods: RRC manifold 70.5mm bore, HR 70mm TB, Hondata gasket, RDX injectors, K tuned fuel system, RRC crank pulley, walbro 225 pump, Exedy 8.9# flywheel
Track info: EH2, 2100 lbs
ERL Superdeck K24 I7 Block 12:5 CR CP pistons
Stock K20A2 Head with Supertech Dual Valve Springs And Titanium Retainers
Drag Cartel Stage 4 Camshafts
Blueprint Ported RBC Manifold
Skunk2 70mm Throttle Body
Karcepts CAI
ebay 4-2-1 headers
Skunk2 76mm cat back
old (lower) graph is same setup with 4-1 ebay header dynoed 5 months ago
301whp 209wtq
KMOD Performance Stg.3 K20/K24 Longblock w/
3.5in CAI
84mm TB
GATO IM
K20a2 cyl. Head
BC Stg.3 Cams
Supertech Valvetrain
87.5mm Supertech 12.5:1 Pistons
Eagle Rods
KMOD Oil Pump/Pan
ASP Header
KMOD 3in exhaust
-Marquis
-KMOD
EP3
Motor: k24a1 88MM 13.3 JE Pistons, Blue Print I Pro Beam Rods
k20a2 Port n Polished Head, Supertech Valvetrain
Header: Buddy Club RH
Cams: Kelford Stage 2.2
Intake: Custom 3in Short Ram w/ Apexi Filter
Exhaust: Invidia Q300 Catback
Tranny: K20a2 6 Speed, Wavetrac LSD, Synchrotech Carbon Synchros,
5.07 Final Drive, TSX 6th Gear
Misc Mods: Skunk2 Throttle Body, Port Matched RBC, RC750CC Injectors
Fuel: E85
Bottom Line (Previous Setup) K20a2 with Kelford Stage 2 Cams
http://www.facebook.com/video/video.php?v=10151302621443526&notif_t=video_processed
EP3
Fuel: E85
I take it this is supposed to be bhp and not whp?
