21 - 40 of 53 Posts
How's the reliability with the 3-pulley setup and electric water pump so far? Also, what alternator did you end up using? On a DD car, would a D-series alternator be perfectly capable or providing enough power?
-Jalal
75 amps is enough for any civic. I think the tsx are more then 100 more like 120amps. As long as you have a solid battery that can start the car. The alternator takes care of the rest. Pdf setup looks good any issues with belts cracking etc?? :up:
Sweet looks like a typical B series Alt setup. Sure won't have any problems. Nice work!!! How much is the kit?
etdracing said:
ETD Racing has that problem solved. We have been working on a part that will solve the pulley problem , I cant say much more but I am sure you guys will love it. We will post some pics soon.
Thanks
John
Any new info on this? I am getting ready to drop my K20a2 into a 95 Vx. Need to take care of this first :up: :up:
I installed the K20a2 pulley on the K24a1 block with the K24a1 water pump..... It was giving me hell to put back the 3 washers in.. Maybe it only needed two instead..... I ended up breaking the top alternator bolt in the water pump...:( Does anyone know what belt would work with this setup.. Or what if I changed back the Water pump to a K20a2 water pump and blocked off the outlet for the oil cooler.... Someone please help...
nice... any idea on price yet?
also is that a tensioner design built in to it?
so it required relocation of the alternator, utilizes stock water pump, and an RSX-S crank pulley, and a to be determined belt length?
and obviously no P/S
21 - 40 of 53 Posts
