Head Gasket Size for bored block
18K views 21 replies 14 participants last post by  CivicRSA
#1 ·
Hey everyone. Just a quick question. I am using a K24 Block bored to 87.50 I wanted to know what size head gasket is acceptable? Does the bore size of the gasket adversly affect the sealing of the Head? For example, Cosworth makes a 89mm gasket for the K20 Head and Cometic makes a 88mm. Apart from specific manufacturing design and materials used by each company, will using one over the other matter for my bore size? Thanks for any input.
#3 ·
Hi, I don't quite understand. Would'nt the 87mm be to small for a block with a 87.50 bore. I though you had to always go bigger or the same size gasket to match the bore of the block. So, what your'e saying is if I go with an 88mm or 89mm they would be too big? Also, how does the thickness effect the compression ratio? Does a thicker head gasket raise or lower the compression of the block? I hope I am making sense. Thanks
#8 · (Edited)
The logic "Better over than under" doesnt necessarily apply to this case here. As Scott said, the 87mm gasket will function just fine with the 87.5mm block. I ran an 86mm headgasket on an 86.5mm setup with no issues..
#15 ·
thats funny because i called cometic about this exact question and they told me to use 88 mm so thats what i bought and i havent had any issues at all. im sure it doesnt really matter since other people have done it both ways.
#14 ·
Hey guys. I have an 87.5pm bore, and the gasket I have is 87mm but measured out to 87.5. So it clears the cylinder bore in almost every part but in some areas the gasket goes slightly into the cylinder.
Should I get a different head gasket or will the piston not hit the gasket. Please any help will be appreciated.
ATM I only have 1 dowel pin on the block but I aligned the other side to check clearance and on the right side of Cyl #4 the gasket bore slightly over laps the Cyl bore. Please LMK.
#16 ·
I'm running 86.5mm bores and originally fitted a cometic 86.5mm gasket which went pop after only one track day. Since been running a Honda oem 86mm gasket and it's been perfect for a good year now.... :up: with much higher boost & power levels.
#17 ·
Would be better to use 88mm gasket than 87. You can get cometic to make you a 87.5
#18 ·
My tuner told me a 87mm would be ok for a moderate tuned motor, he said that extra .010" around would jsut be burned off. Though he said when a motor is tuned to the max like mine and several others on here are, he would imagine that it could pose a slight issue with maybe detonation but he hasnt 'been there done that' he always goes next size up which is what Im going to do.
#20 ·
You need to stop listening to your tuner before he ruins your engine for you, LOL, burn off excess head gasket, LOL good one I havnt had such a good laugh in days.
doing a build as we speak on a k20z3 head on k24a4 block gonna need to bore it out to 87.5mm (spun crank bearing) on a n/a set up running 8 psi whats size gasket should i get thickness and bore,please help??
Why does it need to be bored out for spun crank bearings? I am not questioning the need for being bored out, just the cause behind it.
The head gasket should MATCH the bore dia, a difference in size that overhangs the cylinder walls creates a veritable hotspot that will cause tuning issues with detonation, the same goes for oversized head gaskets where the edge of the cylinder walls then cause the hotspot. We hone the gaskets bores to match the bore dia perfectly.
#19 ·
