Possibly a better alternative to RDX injectors
43K views 73 replies 33 participants last post by  Scourge
#1 ·
OEM k20a3 injectors modded by cutting the screens off.
Part # 16450-PPA-A01 (cost new is about $100/injector, but can be had for WAY less used)
Modify by cutting the screens off.
Send to have them cleaned/flow tested.
I've been running these modded injectors for the better part of a year. Initially I just cut the screens off and ran them w/o having them tested. I ball parked the size to 455cc. The injectors had over 100k miles on them and were not that badly in need of cleaning! I used only BP gasoline in my car, so quality gas does have its long term benefts.
Previously, results from the modded OEM 310cc injectors were posted. The flow rate increased to 520cc and the spray pattern was listed as "good." I'm guessing the spray pattern on the modded OEM 270cc injectors is "excellent" b/c the pintle size is smaller than with the OEM 310cc injectors.
The best part about this? No re-wiring. I HATE re-wiring with a passion. :p
#9 ·
I've been running them in my car for awhile now. Most people do the RSX-s 310cc -> 520cc. I hadn't heard of anyone doing the RSX base/Civic Si 270cc injectors with flow test results. I figured, why not, 520cc is more than I'd need anyhow. The spray pattern comes up better than with the 520's too (which test as "good").
Comptech was selling the modded OEM injectors for $100/each back when you could get the injectors for $60/each from the dealer.
#10 ·
Sweet, I have a set of CRV 270's that I modified this way about 5 months ago, nice to know they flow around 480/490. Great info, looks like I'll be keeping them incase I go to FI or build the engine a bit.
-Froth
#29 ·
Not that anyone has found so far.
OEM 270cc = modded 490cc
OEM 310cc = modded 520cc
RDX are 410cc, but modding them would most likely destroy their excellent spray pattern. For me, the modded 270cc work well b/c they maintain an "excellent" spray pattern as rated by RC after modding. The modded 310cc injectors drop to a "good" spray pattern as rated by RC after modding.
#41 ·
Ive been running modded 270cc CRV injectors as 480cc(set as that in Kpro) for six months now with zero issues, last tank I even did 34.4mpg with them.
-Froth
#42 ·
^^^^I was just gonna ask if everyone was experiencing poor gas mileage...im about to do this mod....maybe that other guy needs to have his injectors cleaned and tested.
