Is anyone on here with a JRSC relocating the IAT sensor to the intake manifold? We all know that the blower creates a lot of heat but nobody has ever talked about measuring it. Normally on the K-series the intake air temperature sensor is located in the intake tube so it is measuring ambient air temps (more or less) while the temps inside the intake manifold are much higher. K-pro includes temp compensation tables so you can adjust the tune for it, but as most set ups are done with a s/c it is kind of pointless.
Here is a quick video showing what I am talking about. The tuner inserted a thermocouple into a vacuum port temporarily to show me the kind of temps the motor is actually seeing.
http://www.youtube.com/watch?v=_woKOdJskIw
I've seen some talk on CRSX about it, but it seems that the consensus there is that unless you have added some cooling solution (after-cooler or water/meth) then it isn't worth the trouble.
My car is currently at the dyno and the guy doing the tuning is recommending that we locate a sensor in the intake manifold.
Why aren't more people doing this? Just curious if there is something I am missing.
Also while I know the temp table exist what exactly do they adjust? Timing? Fuel?
