Page 11 - quick pull video
Page 17 - first 1320 run (13.0) video
Howdy! The following is a build thread for my 1993 Honda Civic Si Hatch. I've always wanted an EG hatch(EH3) since High School. After looking for months online for an unmolested donor, I finally found one. I've owned a few hondas: 1997 GS-R that was MINT! It got stolen of course. A 2005 Civic coupe(temporary replacement for the GS-R) and my current daily, a 1996 GS-R Integra and a 2006 RSX Type-S that's my garage queen.
My goal for this build is simply to have a fun/reliable car to drive. As far as HP/TQ numbers, I'm hoping for around 240/175 with my current bolt-on's. I'm keeping the appearance mostly stock and I'll upgrade the suspension and brakes as I see fit, after all the kinks are ironed out.
This is my parts list as of 10/26/14...
Engine
'08 K24a2 59k miles
50deg VTC Cam Gear
K20 oil pump
EK throttle cable
Custom 3.5 inch intake w/ Injen filter
Hybrid Racing 70mm throttle body
Hybrid Racing Ground Kit
RBC intake manifold (ported to 70mm)
K-Tuned Hall Effect Billet TPS
K-Tuned EP3 pulley
K-Tuned OEM 6an Fuel System
RDX injectors
Walbro 255 fuel pump
Griffin Full-Size radiator
(2) 12" spal slim fans
Innovative Mounts 75a (Hybrid Racing version)
Transmission
'04 Type-S
Type-S flywheel
Exedy OEM clutch
Hybrid Racing Bolt in shifter
Hybrid Racing braided clutch line
Hybrid Racing swap axles
Hybrid Racing shifter cables
Exhaust
PLM K-Swap header (updated version)
K-Teller 3" piping (no resonator)
Apexi Ws3 "Turbo" muffler (3 inch) - SOLD
K-Tuned turn down muffler (3 inch)
Suspension
Function and Form Type-1 coil overs
K-Tuned Pro-Series Traction Bar
DevRacing power steering loop kit
35mm Miracle Cross Bar
Function 7 LCA's
Function 7 Rear chassis brace
Hardrace front camber kit (Pillow-ball)
Hardrace rear camber kit
Electronics
Kpro
Hybrid Racing Conversion Harness
RSX-S Engine Harness+appropriate sensors
Interior
Personal Suede Steering Wheel(Red Stitching) (350mm)
Nardi Deep Corn Woodgrain Steering Wheel (330mm)
Works Bell RAPFIX II quick release
Works Bell Short Boss hub
EP3 Type-R Six-speed shift knob/MPC wooden shift knob
Crow 5-point restraints(Grey)
NRG Harness Bar(custom powder coated)
Bride Vios III Low Max Gradation seats
Exterior/Wheels/Tires
Password JDM Carbon Fiber bumper scoops
Rear Wiper delete
Si Wheels (re-manufactured)
Dunlop Direzza 102's 205/50-15's
Volk Rays 57DR's in black 15x8 +32
225/45-15 Nitto NT01's
SiR Front Lip Spoiler
Spoon CF Duckbill
The following is from the original post...
I've been researching my K swap for awhile now and want to start buying parts. I've read the stickies but want confirmation and feedback on the parts I've chosen. I just bought a 1993 Si hatch.
Driveshaft Shop Performance Axles Level 0
70mm Hybrid Racing Throttle Body
Innovative mounts
RBC intake manifold
Hondata K-Series Intake Manifold Gasket
Spal Electric Fans (IX-30100435)
Hybrid Racing K Swap Bolt-In Short Shifter
Hybrid Racing Performance Shifter Cables
Hybrid Racing K-Swap Clutch Line
Denso Acura RDX Injectors
6AN Center Feed Fuel System
Hondata K-Pro
Griffin Radiator
Type-S flywheel
Ground Kit
Exedy OEM replacement clutch
Billet TPS Sensor - Plug And Play
92-00 Civic / 94-01 Integra K-Swap Traction Bar
I'm wanting the parts list to be as inclusive as possible. Regarding the tranny, I'm waiting on a call from Steve from Hmotors for a Type-R (Y2M3). I want this build to last and be a reliable set up. Eventually, I'll probably cam it and possibly even go with ITB's. Before I call Hybrid Racing and Ktuned I'd appreciate the feedback from you K20a.org guys. Flame away :scared:
Engine
'08 K24a2 59k miles
50deg VTC Cam Gear
K20 oil pump
EK throttle cable
K-Tuned EP3 pulley
RDX injectors
Transmission
'04 Type-S
Type-S flywheel
Exedy OEM clutch
Exhaust
Suspension
Function 7 LCA's
Electronics
Kpro
Interior
Rear Wiper delete
Spoon CF Duckbill
Innovative mounts
RBC intake manifold
Hondata K-Pro
Griffin Radiator
Type-S flywheel
Ground Kit
