CAFROG's EH3 K20A Swap
69K views 234 replies 41 participants last post by  CAFROG
#1 ·
Here's my hatch
'09
'10
After 8+ months of sitting while I saved $$$ (Spring '11)
I've owned it since 1996. Its had the stock D16Z6, B18B1 (installed 1998), and a B16A (installed in 2009)
Here's my previous motor (w/CTR cams, ITR springs, Cam gears....and A/C)
The hatch was my Daily Driver until late last year. It has been a part of me for too long and I am terribly attached to it.
I always wanted a K-Swap (well......for the last 8 years or so) and when it went from the DD to the fun car......I started saving.
I spent a considerable amount of time researching on this site.
I didn't have the funds yet....so time was all I had :silly:
I would like to thank many of you who humored me with your patience and knowledge.
I have very few Honda friends (most of my friends giggle at the EGg) and I have absolutely no one around me who knows K-swaps
I have learned a lot from you guys and I appreciate it.
Thanks to Hybrid Racing (David and Will), Karcepts (Brian), K-Tuned (Mike) and ASP (Stefan)
Now on to the parts:
I was torn between the cheaper way (parting stuff out a piece at a time) or paying for a complete swap from a reputable company or anything in-between
In the end.....I went for the whole swap for its piece of mind, low miles and avoidance of issues with shipping, multiple seller, bogus parts, etc.
I went for a complete K20A swap from HMO
Steve was a great person to work with
The swap came with:
K20A longblock, trans, ECU, shift cables/box, OEM Type-S axles, USDM O2 sensors, Temp sensor and fan relay (for swap)
All these parts went to a machine shop:
I took the transmission off and removed the flywheel for re-surfacing (CC stg 4, OEM Throw Out Bearing and trans parts all greased up per Helms)
I also took the OEM Brake Rotors off (re-surfacing) est.1992!!!
And I bought Karcept's 36mm nut hubs (for the Type-S axles) and OEM bearings
Stock versus Karcepts
On the car
BNIB OEM RBC IM installed
ASP group buy budget header (also bought 3" exhaust kit for my EGg)
Here the engine bay paint after a few swaps and motor removals (sometimes all alone lol)
I took the old trans mount off (for the K-swp mount install)
I took it to a PPG paint store where the matched it for less than $10 OTD
I carefully taped off a few places and shot the bad spots (it ain't a show car) I am happy with the results.
Motor after I just dropped it in (thanks to Big Boy Ross and Chris)
(you can kinda see the improvement from the quicky paint job)
Hasport Mounts
Hybrid Racing Fuel Rail
06 Civic Si idler pulley (easiest install of the whole thing lol)
K-Tuned FPR, Ram Air Intake, Pass Side Radiator/Hoses (only pic I could find :down: I'll get more soon)
Had to cut the hood for clearance with brake booster line (bent nipple down a little) and evap purge
I am no painter and I did it in less than an hour.
Paint results are....meh b/c I used the same rattle can and the hood is fresher paint than the Engine Bay...... but its works!
Grounds I made (soldered)
Looped my PS unit (might want a elec PS unit later) ~$50
On the mini-lift for exhaust
2.5" car sound cat, 2.5"-3" transition, 3" Vibrant Resonator, 3" ASP exhaust kit
I got this Muffler left to put on. I am bitching out and taking it to a exhaust shop b/c the outlet after the suspension is really high and I don't know how to make it clean looking without having the muffler point to the ground :down:
Now on to the problems I ran into:
Swap came with a PRC ECU.....suppose to be a quick and easy ECU for me to start with (K-Pro funds are not here yet lol but its happening by Spring)
Car wouldn't start......I checked as much as I could (grounds, power, injectors, spark, etc)
The injectors were not firing but it everything else was fine
Long story short....called Steve at HMO and asked him. He asked if my PRC had "J01" after it says "PRC".....yes I did
Steve told me it has immobilizer like USDM PRB's.
Dave at HR sent me a Immobilizer Bypass Unit to try.
After I figured out how to get the pins into the clip (thanks Will at HR) the car fired up! (PRC-O13 don't need the imm. bypass unit but PRC-J01 does)
Car had a hunting idle......so I cleaned the IACV (so I thought) but still hunted
Bought a Lisle Coolant Funnel....no air in system but still hunted
Finally I figured out I needed to take the electrical portion off the mechanical portion of the IACV.
Soaked it overnight in carb cleaner and car idled like a dream!
Car had CEL for both O2's. Steve at HMO thought it was odd and said USDM scanners don't read a stock JDM ECU :confused:
I sent pics to Will at HR and my secondary O2 was wired fine. I was stumped.
Last weekend, I got most of the exhaust welded on and I turned the key to the "on" position.....the fuel pump didn't turn on.
I started looking around at wiring and noticed that that one of the leads for the imm bypass was loose.
I reset it in the clip....started the car and the codes were gone :up:
Not sure if that was the issue but all I know is the codes are gone and that stupid light isn't lite on my dash anymore!!
I finally took it for a shake down on Saturday. Drove around slow listening.
U-turns and braking and such.....no issues so I took it out to a country road.
I was pretty nervous (lots of money and time) but finally pushed it in second gear and let VTEC hit.....whoa she rips.:dance:
#7 ·
build is coming along nice man, real clean hatch and the swap sits very nicely in there
Thanks guys.....you both helped educate me through this process.
looking good!
Thanks, Cole. I know your hatch will be looking much nicer than mine when its done.
Can't wait to see you in your next match too :up:
#5 ·
If you read my post.....you can see that I was on a group buy for a ASP header.....its 2.5 collector....no if's, and's or but's about it. And I already had the 2.5" cat from my ITR B-series header. Add to the fact that there are not a lot of companies making 3" collectors makes it a hard find.
But thanks for the comment??
#19 ·
My EJ decided it wasnt going to start today. Kinda forced me to troubleshoot a few things and i ran across something of interest.
There are two switches on the clutch pedal. The upper switch is for starter kill, lower is for cruise control. My switch was fine... but there is a little blue plastic plug that fits in the pedal as a stopper to allow each switch to work...
... mine were both gone. The one for the starter switch was on the floorboard in pieces.
Since each switch has to be pressed for a closed circuit... if your switch is bad or that plastic plug is missing... no start... or no cruise... depending on which switch youre looking at. Easy way to see if the switch is bad is to unplug it and short the harness plug with a paperclip.
Remove the under dash plastic access cover and knee bolster. Unplug everything from the under dash fusebox, pull the two 10mm nuts that hold it in place, move it down and you have easy no neck breaking access to both clutch pedal plugs.
Just tossing out things i run across workin on this pile...
#20 ·
Got me thinking I need to look at mine now to see if the Cruise Problem is there. The 2 other swaps (B-series) never had an issue with the cruise but I know what you are talking about and it is a fun experience getting under that dash (I'm 6'2")
Got my first K-swap Kill on a 350Z.....didn't even know the guy but I passed him on a back highway pretty hard so he wanted to play.
He kept with me from a dig until I grabbed.....not until I got in 3rd gear. I pulled him hard after that.
We also did a 60mph roll and I walked away really quick (even though I accidentally took off late)
I had a full tank but he had a passenger (who got the 60mph roll on his iPhone lol)
#24 ·
Not daily driven......weekend fun. Stupid JDM Engine Harness makes me go without a heater (seems too tight to get it back in) Plus the mounts and clutch......and 3" exhaust.....not a fun DD in comparison to my 05 4Runner.
But....yes, I am having fun with it lol. Its about the car and what it can do....how it is underestimated and mocked. These are the things that encourage me to improve it and shut people up. So walking away from the 350Z (when he jumped me) was priceless. I like the shock and awe.....and I got soem shock and awe when they pulled up bedside me to give me props.....they didn't know but now they do lol
Glad to see you got the kinks worked out! :up:
Thanks for your patience and help!
#25 ·
My 92 PS rack is rubbing against my transmission and the rack is leaking sOmewhere around the gear box.
Hasport EGK1 mounts
Found out this is a problem with some ex and si civic PS racks (one with three bolt bottom plate)
Went to a recycle center and found a 92-95 civic manual rack for $70
Need new tie rod ends, allignment and other budget stuff that'll wait until after the holidays.
#26 ·
good looking car dude! i really dig it :) :up:
#32 ·
Got my manual rack in.
Just got new tie rod ends and dust covers.
And a K-Tuned traction bar is on its way :up: thanks, Mike.
Get the parts on and an alignment....and I'll see what it runs (1/4 mile) with the 3-bolts and street tires.
A while ago (year or two) I bought some 13X8 22" slicks but I'm thinking they are too small for the 4.7FD (aka into 5th gear) might need to sell them :what:
#38 ·
Here's a picture comparison of the steering rack clearances. You can still see the dirty grime on the trans from the PS fluid leaking. new tie rod ends and dust covers on the manual rack. Aligned yesterday :up:
And the newest addition to the money pit....K-Tuned/ETD traction bar. Super solid piece. Love how it mounts in two places on the LCA....many only mount in one spot. This is stronger and much more straight forward of an install (no worry of axis and correct positioning). Thanks to Mike at K-Tuned. He's been good to me.
#39 ·
MADDD clearance!!! Must have... :up:
Mike/KTuned :up:
Interest in spinnin wrenches on my car... :down:
lol
You need a GoPro suction cupped to the side of your car behind a front wheel... and go for a ride... i wanna remember what a pissed off TypeR sounds like at 8k. It might relight that fire under my arse...
Theres like no incentive around here to work on my car. Every Civic i see has a fart can on it... and all the 350z's are whatever. I havent even really seen a Mustang/Camaro worth turnin the key on the EJ for...
