i need to order an engine stand to work on my block. what brand do you guys recommend? i was just gonna go with some $50 one i found that holds 1000lbs., but just wanted to see what you guys have to work on your k series motors.
Yeah thats somthing like i got. its called a pro-lift or somthing, and mine has had many motors on it :up: not bad for 40 buxkommon_sense said:I spent $40 on a stand at the local autoparts store. Stand only holds 750lbs, but the motor doesn't even weigh 400, so plenty of room there![]()
You doing your own rebuild now?pnoyboldstar said:i need to order an engine stand to work on my block. what brand do you guys recommend? i was just gonna go with some $50 one i found that holds 1000lbs., but just wanted to see what you guys have to work on your k series motors.
