Sup yall, I wanted to see what radiator setups you guys are running on your turbo K specifically in a eg, I'm running a mishimoto half rad with a 12 inch hybrid racing slim fan and i recently put on a shroud a couple days ago to try to control the temps.. didn't work out temps have been up to 208 cruising on freeway at a stop it cools down, it ran cooler without the shroud cruising on the freeway... I've looked through the forums to see what people run and haven't really seen a good thread with good responses, Im running water with vp cool down through the system right now, really leaning to get a full radiator setup with dual fans but which setup would be best...? thanks for the input. best thread ive read so far was this one https://www.k20a.org/threads/good-radiator-set-up-turbo-k-swapped-eg.113807/#post-1802216
