Hi guys,
im using an oil filter relocation (k20/24 going into a lotus) because the oil temps are worse due to the engine location so im running another oil cooler and not using the stock one which is under the oil filter.
The relocation take off plate appears to use the standard union bolt part which holds the stock cooler to the block and acts as a thread to hold on the filter. Problem is, the part is long due to the standard cooler. So without the stock cooler does anyone know of a union bolt which i can use instead? Surely the union bolt cant thread in enough to make up for the lack of oil filter.
This is the union i have now
This looks like what i need
