21 - 40 of 553 Posts
Discussion starter · #21 ·
Re: Official Registry: Quarter Mile Quickest All Motor Times On Slicks
Damn!!!! Nice 60!
Updated.
k20a2 untune....rcrew header, kpro and intake...
12.7 at 107 mph..1.8 60's...13 m&h drag slicks
96 ek gutted seats...front and back.
12.31 @107.12,1.64 60 foot/EG 92 hatch, K-pro,k20 head-k24 block,skunk pro 1 cams, stock block 9.5 comp pistons, Type trans/ 23.0-8.0-13 slicks/@2780 ft.
Discussion starter · #26 ·
Have you ever weighed your car and what size slicks?
allmotorwhore said:
12.31 @107.12/k20 head-k24 block/ 23.0-8.0-13 slicks
What do your mods consist of, and whats your weight along with what chasis is this in?
Just wanted to add that the track is at high elevation. Get this car to Pomona and we'll see mid 11's. Not to bad for a stock internal car.:)
allmtrallday said:
what 60 did you guys pull on that run? good shit dude. 11s for sure...:up:
Kpro, sparks hearder,52mm itb's twm, 2340 pounds. The 60's were 1.63 all day. The last run against the infamous lucky mike was a 1.7 60's managing 107 mph all day long. This would equate to a very low 11 second pass due to elevation corection. :dance:
Discussion starter · #29 ·
Im guessing this was in a EG correct?
Discussion starter · #31 ·
What does your setup consist of? And what size slicks were you using?
Discussion starter · #33 ·
allmotorwhore said:
YEs you are correct Sir!
Im guessing your in CA, what EMS are you using? And is your car tuned?
Yes, santa barbara CA. I am running a kpro hondata computer, tuned by bubba of do it dyno.
12.1@109 at hrp 1830lbs with driver 24.5x8 m&h 1.6 60ft. Comin out the hole at 9k on stock 03 si axles
stock k20a2 440cc inj. kpro
190whp
1992 cx hb
Modified type s exhaust manifold
110 racegas
One piece frontend
2gallon fuelcell a1000 fuel pump
Discussion starter · #36 ·
Was that with stock header? Could you be more specific on the chassis? Open Header? Need more info. Could you also respond in the format i asked in the begging of this thread? Thanks!
Discussion starter · #40 ·
What header are you running? And what size slicks beyond 23inches tall?
And what does your setup consist of?
allmtrallday said:
went a new personal best yesterday at CMI in sacramento.
11.65@115.1 still same set up. :up:
Updated. Also what size slicks was this on? same 23incher's?
