Hey guys im trying to devise a List of all the All Motor Cars Running the Quickest Times On Slicks. If you have a Time you Want to Submit Please Submit it to me In this Format So I can Keep It in Order.
Username - State / ET@MPH / Chassis/Motor Type (k24,k20,k20R, Etc. + Modifications) / Weight w Driver / Tire Size
*Cut Off is 13.00 People*
If you guys have any suggestions on how maybe to list this better feel free to chime in. :up:
ALSO PLEASE DON'T PM ME YOUR TIMES, POST ON THIS THREAD, AND WHEN I OR THE OTHER MODERATORS ARE NOT BUSY WE WILL UPDATE IT!
Also please people, if you want your times entered in this registry please please please follow my format... give me your exact parameters that i am asking for, if not then you will not be entered until done so.
- K20pinay - CA / 9.87@139.8 / CRX K24K24 /Go Power Dog Box/ Go Power Cams, Header,Headwork, Crank / Kinsler ITBs / 1650 lbs. / M/T 26x8.5x15
- Felipe_Johannpeter - RS Brazil / 10,155@130.6MPH / Honda Fit / modified k20/k24 / 1700 lbs / 24.5x9x15
- Vert - CA / 10.19@135.2MPH / CRX K20 / 1825 lbs. / M/T: 26"x8.5'x15"
- regamaster - ?? / 10.33@135 / CRX K24 / 103mm Crank / Go Power Cams / Headwork / Custom Go Power Header + Go Power Dogbox / 1738 lbs / MT 26x8.5x15
- 1fstHF - NV / 10.46@130.4 / EG VX/Modified K24/K20, Drag Cartel 4.5's, ITB's, K-Pro / 2170lbs / M&H 25.0/8/13 Slicks
- Boostedgsr-si - TX / 10.5@126 / 95 Civic Hatch /k24 stock sleeves, sk2-2 / 1750 w Driver / 24.5x15s
- HumbleEG - OK / 10.56@128mph / Built K24 / 2172lbs w/driver / 24.5 x 9 x 13
- Onefstek aka Stefan @ ASP / 10.72@124.7 / 2150 lbs 2000 Civic EK / 24.5/9/13 slicks
- SPL Dan - FL /10.79@127 / EG CX Hatch / Built K24/K20 / 2100lbs race weight / 24X8X13 MT Slicks
- H2Nr - MO / 10.82@124 / EG hatch K24 Modified/ Hytech cams/ 2150 lbs / M&H 25/9/13
- Marc P - FL / 10.83@125.5/ EG Drag Cartel/ERL K24modified / 2220 / 24.5x8.5x13
- Jeremyinlinepro - VA / 10.89@126.99 / EG K20 Modified / 2200lbs / 24.5/x/13
- GOTSLICKS - pa / 10.90@128.2 / Honda Insight/ k24-k20z3 / 88-99 stock z3 head,kelforb b,rdx 440,kinsler 62, / 2100 / 23"
- Allmotorb18c - NJ / 10.91@122.98 / EG K24 Modified/2040lbs / 24.5x8.5x13
- Clockedout - CA / 10.94@121.9 / EG -tube back-half /K24 - stock crank, custom GO Power Cams, Portflow headwork, RCrew Header, K-Pro / 1785lbs / M/H: 25x8.7x13
- eg6onboost - NJ / 11.031@122.7 / 24.5x9x13 / 2168 with driver
- Tainted - VA / 11.27@123 / Modified k24/20 head/R-Crew header/3"exhaust / 2250lbs / 24.5/9/13 m&h
- tsrperf - MD / 11.2@120 / EG K24A1 (Blueprint Motor) / 2161lbs / 24.5x9x13
- RacerX023 - CA / 11.2 @ 116mph / 95 Civic K20 Type R / RBC Manifold, stock throttle body, R-Crew Cams, R-crew Header + K-pro Tuned, 650cc injectors / ???lbs / 24.5x8x13 MH Slicks
- Marc P - FL / 11.2@116 / EG Drag Cartel/ERL K24modified / 2190 / 24.5x8.5x13
- non vtec - NZ / 11.30@118 / EG K20a2 TWM ITB's/SSR 4-2-1/Megaphone/Crower Cams + Kpro Tuned / ????lbs 24.5/8.5/13 M&H Slicks
- gotslicks - PA / 11.3@119 / HONDA INSIGHT / BUILT 12.5 88MM K24/20 KELFORD 179B s2pro 74tb / 2115LBS / 23X8
- Sicksilver_ep3 - AR / 11.30@ 119.27/ ek hatch/ k24 12.5:1, 4 piston 156, cartel 4's, still on rbc manifold. / 2370 lbs / 23x8x13
- Wsuk20 - WA / 11.31@120 / EG / K20, Ross Pistons, Crower Rods, Toda Type 15 cams, SDS management / 1850 lbs / 26/8.0/15
- CRXEE8 - Denmark / 11.35@124.7 / EG HB / K24 / 2200 lbs / 23x8x13
- cxcivic - FL / 11.40@118 / CRX /TSX w/K20 head/ DTR 4-2-1Header/Kpro + street Tune / 2000lbs / 23/8/13 M&H Slicks
- hon+da_b_blastn - Australia / 11.41@119.8 /EG HB /K24 modified/ 2099lbs / 24.5-8-13's
- allmotorwhore - CA / 11.41@119.3 / EG K20a2/k24 Sparks Racing header /52MM ITBs /12.7 IB spec pistons Skunk Stg. 1 Cams + Kpro Tuned / 2280 lbs / 24.5-13-8.5
- allmtrallday - CA / 11.42@119.9 / EG HB k24 Modified / Excess IM ported out + Kpro Tuned / 2200lbs / 24.5/8/13
- Boostedgsr-SI - TX / 305-220 / 11.45@120 / K24A1 DC2/ built, stock sleeves, e85, Kpro / 2300lbs w/driver / 24.5" M&H slicks
- K-Unit - NJ / 11.48 @116.53/ EK K20/ rbc manifold/r-crew header/ skunk 2 Pro3 Cams k-pro + Tuned / 2108lbs / 23x8x13 MH Slicks
- Palma4dr - NJ / 11.50@116 / K20A2 eg hatch/ Rcrew header, Rcrew Cams, pump gas, Kpro / 2???lbs / 23" M&H slicks
- JuanK20 - NY / 11.55@106 / EG Hatch / K24 Modified/ IPS Cams/ DTR Header/ CP Pistons/ PUMP GAS/ K-pro / 2200lbs / 24x9x13 Slicks
- ALLMOTAMAK - CAN / 11.59@116 /93 EG/K20A2 RBC, Crower stg2 cams / + Tuning /2120lbs / 23X8X13 M&H
- eg6k - NY / 11.66@122 / EG / K24-Hytech, drag cartel stage 4, ips manifold / DRT TUNED 24.5x8.5x13
- ldegsick - VA / 11.677@115.30/ eg hatch, k24 modified, rbc mani, stock trottle body, r-crew headers)/ 2325lbs/ m&h 24.5x8x13
- 1fstHF - NV / 11.68@116.34 / EG VX/Modified K24/K20, Skunk2 Stg3 cams, RBC IM, K-Pro / 2200lbs / M&H 24.5/8/13 Slicks
- dnrprojectsvp - CA / 11.7@117 / K24 ek hatch/ SSR/DTR header, IPS kme, 12.5:1 comp, pump gas, Kpro / 24.5x9.5x13 M&H slicks
- NHSwaps13203 - CT / 11.71@113.62 / CX EG / K20a2 + Blueprint2's,RDX injs, Hytech Rep 3inch intake and exhaust / yosolo 238/163 / 2035 / 23x8x13 mh
- eg5 - Australia / 11.73@113.17 / EG hatch / K24A TSX stock bottom end (JDMyard IM , 80mm TB , JDMyard Header , Buddyclub N+ cams ) / 2024 lbs incl driver / 24.5x8x13
- xtrafastcrx - CA / 11.73@113.3 / eg vx / K20z1 (Ported RBC, 70mm TB) / 2250 / 23x8x13
- Trujillokcoupe - NY / 11.743@117.13 / ej1 coupe / k24k20 itbs / 2235 / 24.5x13x8.5 / honda day 2012
- dblock - NJ / 11.78@114 / K20A2 eg hatch/ Rcrew header, s2 cams, pump gas, Kpro / 2???lbs / 23" M&H slicks
- Jo tech / 11.78@116 / k20/k24 all motor / 2720lb w driver / 24.5x8x15 slick M&H civic 08
- SpeedDreamz.com - ? / 11.8@119 / EGk24 Modified / 2280lbs / xx/xx/xx
- Midnight Auto - NY / 11.813@114.89 / EG Si /K24/K20 11.7:1CR, IPS K2's, 52mm TWM ITB's, K-Pro / 2340lbs / M&H 24.5/8/13 Slicks
- eg5 - Australia / 11.823sec @113.6mph / EG hatch / K24A TSX / JDMyard header / JDMyard intake manifold / 80mm TB / 3 inch exhaust / KPRO/ 2050lbs / MT 24.5x8x13
- NHSwaps13203 - CT / 11.84@113.99 / CX EG/K20A2 Open Hytech rep,Blueprint2,RBC,3inch int with Vstack,Yosolo Kpro 238/163 / 2xxx / 23x8x13
- Orlando BYTuning - NJ / 11.87@111.6/ EG K24a2 RBC Mani./I/DTR
Header/E + AEM EMS Tuned / 2210lbs / 25/8/13 M&H slicks
- WTFisaK24 - NJ / 11.89@114.3 / K24/K20Modified / Rcrew header, Rcrew Cams, 3" Ex, RBC, Kpro / 2250lbs. / MT 24.5/9/13
- gotslicks - PA / 11.9@117 / HONDA INSIGHT / BUILT 12.5 88MM K24/20 KELFORD 179B RBC / 2200?LBS / 23X8
- K-Unit - NJ / 11.90@112.65 / EGk24a2 RBC Manifold/Sparks Racing
Header/ + Kpro Tuned / 2102 lbs / 24.5/8/13 M&H Slicks
- Rocket_launcher-Florida/ 11.9@108/ eg hatch/stock k20a2-rbc-E85-dtr header-3 inch exhaust-233hp / 2160/ 23x8x13
- Oh K k K - NC / 11.92 @ 109 / Ek Snatch /Z3 Longblock Stock, Full Exhaust, TB,etc../ 2300lbs / M&H 23x8x13
- jNYCe5 - NJ / 11.928@114.14 / 88 EF Hatch / Stock k20a2 w/ SSR Race Header and K-Pro / 1945lbs / 23x8x13 M&H
- Garenty - Montreal/Canada / 11.93 @ 115.7mph / 1996 EK/ K24 type-s head IPS cams & supertech springs / prb intake / r-crew header / 2375lbs / M/H 23x8x13
- Jeff 16 - NY /11.94@114.98 / Ek K24 Modified/2400lbs / 24.5x8.5x15
- NABeastRR - FL / 11.98@112 /K24a2/ RRC Mani/KR Header/3inch exhaust + Kpro 243WHP / 2330lbs / 23/8/13
- RedEG - TN / 12.03@111.11 /EG HB /Modified inlinepro k24/k20 ,IPS K2, (Blueprint RBC, 70mm Shunk2 TB / h2.NRS MO. tuned K-pro / hytech header / 2360 / MT 22/8/13
- dcoghlan-AUSTRALIA/ 12.05@120 / DC5R-RSX / Drag Cartel/ERL K24modified, IPS IM, ASP Header / 2654lbs inc Driver / 24.5x8x15 MT Slicks
- WinksK20aHatch - LA / 12.07 @ 111.07 / K20A EG / BC Stage 2 Cams / K-Pro dyno'd (221.56 to the wheels) / 2157lbs. / M&H Slicks 23x7x15
- Eg6k20a2-south Dakota / 12.108@114.8 / crx / k24/20 / SvM 211.4 / rbc 74 tb budget header and 2.5 all way back / 2045 / 22x15 slicks
- KESE-KMODRSX , NC / 12.19 @112.5 / DC5 RSX /k24a1, GATO IM, KMOD 4-1 Header, Kelford stg.2s, KMOD tuned / 2692 lbs / 24.5 x 8.5 x 15 M&H
- jdmchop , CT / 12.1 @112 / eg si /k24a2 52mm itbs,rep header,2.3'' exh, yosolo tuned / 2175 lbs / 24.5 x 9 x 15
- eg515 - NJ 12.1/ k20 all motor/ rbc, hytech headers,3inch exhaust,/ yosolo tuned 225 e-town nj
- xcell - NC / 12.2@111 / EF K24/k20a2 Hondata IM Gasket/CAI/Hasport header/ 2.5 Exhaust + Kpro Street tuned / 2100lbs / 24.5/8.0/13 Slicks
- na200whp - FL / 12.2@109 / RBC Mani/SSR 4-2-1/3inch exhaust + Kpro Street Tune / 2100lbs / 24.5/8/13
- dat-dude-ch - NJ /12.2@109 / k20 eg coupe RBC/r-crew header /aem ems tuned /2224lbs / 23-8-13 m&h slicks
sickcivic51501 - NJ / 12.2 @ 109 / 93 civic hatchback / k20 (rbc manifold, hytech header, k pro yosolo tuned) 2??? 23x8x13 m&h slicks
- yosolo - NJ / 12.2@108 / EG K20a2 I/DC TSX Header/E + AEM EMS Tuned/ 2294lbs/ 23/8/13 M&H Slicks
- allmtrallday 2nd Car - CA / 12.2@108 / EG HB K20a2 R-crew Header + Kpro Untuned / 2200lbs / 23/8/13
- cx-k - VA / 12.2@107 / EG hatch/ K20Z1/ RBC,RDX Injectors, DTR header, KPro tuned / 2325lbs / M&H 23/8/13
- gs4 - KS / 12.2x@114 / egk24k20 k2's, 12.5 to 1 c/r, bp rods full weight with ac / 24.5X8X13
- Beavis@tsr - MD / 12.228@112.3 / DC5 RSX/ K24 12.5 comp / Ported head / Brian Crower stg 2 / JR custom header/ 3in. exh./ RBC im with vel.stack/ K-pro / tuned by Mike@tsr / 2660lbs / M&H 23x8x15
- NHSwaps13203 - CT / 12.29 @111.46 / 91 EF HB/K20A2,RBC,DCRH,BPRNT MFG STG 2 cams/ 2156lbs / 22x8x15
- NHswaps13203 - CT / 12.22@111.36 / k20a2 / stg2cams / eg cx / 23x8x13
- Damo - AUSTRALIA / 12.32 @ 108.21mph / dc2 / JDM k20a motor + gearbox , JDMyard Intake Manifold + 75MM TB , SSR header + 3 inch exhaust + Metal Cat, KPRO / 2235lbs / 23x8.5x15 slicks.
- jorgie583 - ?? /12.34@112.68 / EK hatch / k24 modified / tuned /2300lbs/MH 24.5
- BlackEGK20A - Quebec / 12.36@109.37mph / EG SI HB / stock K20A2 CAI / SSR 4-1 / 3" exhaust / k-pro street tune / cusco lsd / 2400lbs / MT 22/8/15
- Quiocho8o8 - Hawaii - Maui / 12.41@109 / EK Hatch / K20 K24 Frank K-Pro street tuned 6 speed bolt ons / weight unknown / 24.5-8-13
- RS Motors - MN / 12.41 @ 110 / EF K20a2 / Custom header,skunk2 cams,kpro / 2450lbs / 24.5*8*13/
- EGhatchNJ - NJ / 12.43@110.3 / EG SI HB / K20A2-3inch int with velocity stack-RBC-SSR header-3in exhaust-KPRO UNTUNED / 24xx with driver / 23x8x13
- yosolo 2nd Car - NJ / 12.43@109 / DC2 K20a2 I/R Crew Header/ R Crew Cams / 3" E + KPRO Tuned / 2545lbs / 23/8.0/13 M&H Slicks
- flesh199 - quebec / 12.4@110 / ek sedan k24/k20 allmotor 279whp/207tq/ 2578lbs / 24.5x8x13 slick
- xtcat8k - VA / 12.4@107 / EK K20AR CAI/Rcrew header/Rcrew PIMP + Kpro tuned / 24xxlbs / M&H 22/8.0/13
- 03DC5R - AUSTRALIA / 12.445@109.92MPH / DC5 / Fully Built K24 / 2,643lb / 23x8.5x15 M&H Slicks
- kdbatmobile - CA / 12.5@108 / EG / K20A rcrew header, custom intake, k-pro/22x8x13
- sleeper6speg - NC / 12.51@109 /93 civic k20a2 kpro tuned/custom 3inch intake with velocity stack/rbc intake manifold/hasport header/apexi 2 3/8" n1 exhaust / 2150lbs /M/t: 22x8x15
- Brentd2319 / Hybrid-Werks / 12.52 @ 108.91 MPH / 93' EG coupe EX full interior STOCK K20Z1 motor (stock intake manifold & TB), ITR transmission - 8x23x13 M&H RaceMaster slicks.
- 6spd EK- VA / 12.57 @ 107.7 /EK Hatch/ K20A2 (K-pro, SSR, Velocity Stack) / 23XX lbs / M&H 22x9x13
- VTX Aviator - FL / 12.578@107.26 / EK Sedan / K20a / RBC / R-Crew header / CAI / tuned / 2450 lbs / MT 24.5x7.13
- yeven_stas - WA / 12.58@106.99mph / eg / (stock k20a2 220.170 / asp header/ ported rbc/ 3in cold air/ kpro Asp tuned)2300lbs / 22x8x15
- MarkyMark203 / 12.60 @109mph / EK Coupe / stock k20z3 11.7:1 UNTUNED / Lightened. Lexan. 22" Lensos / 22x8x13 m/t
- Sicksilver_ep3 - IL / 12.623@ 104.72 / ek hatch/ k20a bp stg 2, dtr 4-2-1, 3 inch, RBC, vstak, / 2400 lbs / 23x8x13
- dc2eg6 - CA / 12.66@ 105.4 / EG CX / K20A2 R Crew headers + k-pro(R Crew Program) / 2xxxlbs / MT 22/8/13
- ek20hatch - ?? / 12.7@107 / EK k20a2 Rcrew header/CAI + Kpro Basemap / 2xxx lbs / ??/??/13 M&H Slicks
- tony4380 - GA / 12.70@107.40 / k20a2 crx hf / DC swap header / custom cool air intake / 3 inch exhaust / KPRO on air fuel tune / 2150lbs / MT ET Drag 24.5x8.0x13
- NA - VA / 12.7@105 / EK K20a2 Rcrew header/CAI + Kpro Base Map / 2475lbs/ 22x8x15
- JustinD - AZ / 12.76 @ 106 MPH / EK / K24a2 / IPS KME's / Cunningham Rods / JE 12.5:1 Pistons / RBC / CAI / SSR Header / Kpro Tuned / 2220lbs / 24/8/15 Mickey Thompson Slicks
- Pistol Pete - Toronto / 12.78@106.55 / K20a2 EG SI/ Drag Cartel DIC/RRC /70mm TB/CAI/ K-Pro /K-Tuned Ram Header/ 2400lbs / MT 22x8x15
- boosted98acura - PA / 12.78@108.7mph / 1998 DC4 stock k20a2/kpro/Z1 cams/3in exhaust/Hytech rep. header/ 230whp 169wtq / 2580lbs w/driver / 22x8x15
- import_boi - WI / 12.78 / eg / k20a stock motor, stock trans with ghetto rid cold air, dc sport headers, exhaust. rims 15in with mt 24.5x8
- Bboy_Burst - CA / 12.8@107MPH / FG2 / K20Z3 (I/H/K2/FP/TB/PM/OP/FD/IMG/MM) / 2900LB / 23-7.5-15
- 92EGK20 - NY - 12.81 @ 107.23/ '92 EG Sedan/ K20z1(BP stg 2 cams, RBC, Hytech header, 2.5" exh, Type-R LSD, K-Pro) / 222whp/175wtq / 24.5x8x13 MT slicks
- Charmersfh - Minneapolis, Minnesota / 12.831 @ 105.98MPH / 1993 Civic Si (K20R, RBC IM, R-Crew headers, K-Pro) 222HP & 159TQ / Full Interior weight 2350(?) / 23x8x13's
- k20eg8 - OK / 12.84@103.4 / EG sedan k20a2 R Crew Header, PIMP, intake/ kpro tuned 212hp/162lbft/ 2550lbs/22x8x13
- KYjerry414 - KY / 12.86@107.26 / EG SI / RBC manifold / K-pro street tuned / 2600lbs / M&H slicks 22X8X13
- Crx2nr822 - CA / 12.87@105 / 88 Crx HF / K20a (3 in. custom intake, SSR 4-2-1 header (open header), Tuned on Kpro) / 2160 with driver / 23x8x13 M/H slicks / Stock Type R 6speed w/ stock clutch
- Mike@ETD Racing - CAN / 12.89@106 mph / EG hatch / K20A2 w/RBC & KPro base-map / 2180lbs / MT 22x8x15
- Jdm_risa - CA / 12.99@104.78mph / DC2 stock k20/kpro/3in cai custom/3in thermal exhaust/rcrew header/ 2700lbs w/driver / 22x8x15
- Redlinef22c1 - LA / 12.99@108.95 mph / EG hatch / K20A2 w/RBC & KPro base-map /DCRH / Apexi WS2 / 2000lbs? / M&H 23x7.5x15
