So I got the EK AC kit, installed it with zero issues. When it came to the wiring, I used the instructions on wiring the relay on the website. Is there a switch I'm supposed to be using as well to kick the compressor, fan on? Only things I wired up was:
12v when car runs to pin85
Ground to Pin87
Pin 30 to C131 pin19 blk red wire
Pin 86 to C131 pin7 blue red wire
I had the unit pressure tested (passed) and then filled with 1.8lbs of r134. I can't get the compressor to kick on or the fan. What am I missing? I'm using the RYwire conversion harness and Kpro.
Edit: so after looking at the CD that the kit came with instead of the online instructions, because I'm using Kpro, looks like I have to re pin 2 wires instead of using the relay supplied. where do I get pins to insert into the kpro harness?
Ground to Pin87
