2002 Acura RSX (BASE MODEL)
1.7K views 5 replies 5 participants last post by  Grandprix
#1 ·
I have a question, I know the Type S uses the K20A2, is it pretty much a plug an play swap if i wanted to get rid of the k20a3, and just swap it in and use the k20a3 tranny? '
lmk
#2 ·
as far as physically swapping it,yes,it should be plug and play as far as things like axles and mounts are concerned.The only thing I can think of that would have to be changed would be the ECU and maybe some sensors.*assuming you are coming from a 5 speed K20A3..if it's automatic then there's the shifter box and cables to deal with aswell as adding a clutch pedal.
