Hi mates,
Im Alessandro and i came from Italy.
My project is K24Z3/K20A2 frankie on my eg6.
When I start to planning, i would use A block, but when i find a cheap Z block, i choose that.
Here is the topic.
http://www.k20a.org/forum/showthread.php?t=89413
After that i start prepare the car. I no want go OT on the topic about the engine, so i open this for speak about my car.
Here below some pics of my car and what I done until now:
k20a2 head grinded, polished and checked hermetic.
oem k20a2 cams, valves and spring.
k24z3 head gasket
k20a2 oil pump
k20a2 baffle
golden eagle bolt and stud kit
k20a2 injectors
ep3 gearbox (unfortunately it not fit on k24Z3, different position of fitting holes and shafts)
thread and plug k24 oil pump hole
i would say thanks to Damian and Maciek, my 2 polish friends that take care my engine.
And also to all the people that help to me in this thread, especially Signalpuke :up:
I know you see many times a building same mine, but in italy i think is the first, so im excited eheehhe
Engine at home :new_slayer:
here i am, im studying wiring.
As Signalpuke told, the better way to understand if switch or not ckp wires, is looking service manual of eudm accord, but i not find yet.
the order of the colors, eudm k24 ckp sensor is same k20 ckp sensor.
So need switch anything.
K24Z3 EUDM
K20A2 EUDM
stuff arrived
K24 HASPORT MOUNTS
K-SWAP CLUTCH LINE
70mm THROTTLE BODY
CRV BRACKET
RBC INTAKE MANIFOLD PORTED TO 70mm
K-TUNED THROTTLE BODY ADAPTER
K-TUNED SHIFTER PLATE
RSX-S DRIVE AND INTERMEDIATE SHAFT
K-TUNED FUEL RAIL
WALBRO 255LPH FUEL PUMP
BLOX INTAKE HEATSHIELD
IACV ROTATION PLATE
Saturday, 4th August, SWAP STARTED
few pics of the swap
Uploaded with ImageShack.us
Sunday 5th August
Today i have a rest, no do nothing, just remove ABS pump and thinking how relocate it. The right place is where is located the main battery
First problem:
CRV oem bracket not match the Z block.
so i modified it
working on axles.
I take RSX axles, i switch the inners, i remove K series outers and i replaced them with Bseries.
I start the work like a professional mechanic, all the steps in my mind, all the tools that i need, faschon gloves
Shot at 2012-08-17
After short time, I spent a lot of time for remove the outers, and i finished my patience and cleaning work :lolface:
the pics can speak by itselves
Shot at 2012-08-17
Shot at 2012-08-17
Shot at 2012-08-17
Shot at 2012-08-17
But at the end...mission complete
Shot at 2012-08-17
working on the dashboard
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
i want let u know about the difference between K24Z3 and K24A3 water pump.
They seems same, but one of the upper fixing holes is in different position.
A3 have the 2 upper hole in line;
Z3 have the 2 upper holes NOT in line
This is another difference between the 2 motors, like the problem that I had with CRV bracket that the bottom hole no match the hole on the block.
You can read about this problem in the previous pages.
Weld cast iron isnt easy, so i choose for cut little bit the bracket for fit the screw and i put a big and hard washer for lock the bracket.
See the pics about water pumps
Shot at 2012-08-28
Shot at 2012-08-28
hasport mounts painted in black
operations for remove passenger mount
DONE!
about this pic ask to my friend
after fitted hasport mount, i mark where drill the holes
Need only painting
ABS RELOCATED
I must relocated the ABS unit because the engine hit it.
I put ABS Unit where were the battery.
Grinding little bit the support
The ABS Unit must be positioned with the front face to the firewall.
For lock it i use the nut of front camber kit.
1st pipe repositioned
2nd pipe repositioned
others 2
another 1
how the work look like now
the last pipe from right front wheel is too short.
must be replaced with another one longer.
removed
on the ABS pipes there is a hard rubber for protect them.
On this new pipe the hard rubber isnt ini the right position, so i use a plastic hose to cover.
Work finished
Here is the topic.
k24z3 head gasket
k20a2 oil pump
k20a2 baffle
k20a2 injectors
K24Z3 EUDM
K20A2 EUDM
stuff arrived
K24 HASPORT MOUNTS
K-SWAP CLUTCH LINE
70mm THROTTLE BODY
CRV BRACKET
K-TUNED FUEL RAIL
IACV ROTATION PLATE
Sunday 5th August
First problem:
so i modified it
working on axles.
Shot at 2012-08-17
Shot at 2012-08-17
Shot at 2012-08-17
Shot at 2012-08-17
Shot at 2012-08-17
Shot at 2012-08-17
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-19
Shot at 2012-08-28
Shot at 2012-08-28
DONE!
Need only painting
ABS RELOCATED
others 2
another 1
removed
Work finished
