Oil Pumps - I've been reading old posts
15K views 16 replies 8 participants last post by  an2ny888
to answer OP's question
Yes you can use the Z3 oil pump for 8k rpm.
Yes it does have the balancing shafts
Yes it will cut down on vibration compared to the type-S
The type-S without shafts is good for a few hp and more vibration than the Z3
Most of the time people that are building K24's go with type-s because it's a 'while you're in there' mod that is relatively easy.
