Official Registry: 1/4 Mile Quickest All Motor Times On Slicks
4 reading
177K views 552 replies 180 participants last post by  sportsman1539
#1 · (Edited by Moderator)
Hey guys im trying to devise a List of all the All Motor Cars Running the Quickest Times On Slicks. If you have a Time you Want to Submit Please Submit it to me In this Format So I can Keep It in Order.
Username - State / ET@MPH / Chassis/Motor Type (k24,k20,k20R, Etc. + Modifications) / Weight w Driver / Tire Size
  1. K20pinay - CA / 9.87@139.8 / CRX K24K24 /Go Power Dog Box/ Go Power Cams, Header,Headwork, Crank / Kinsler ITBs / 1650 lbs. / M/T 26x8.5x15
  2. Felipe_Johannpeter - RS Brazil / 10,155@130.6MPH / Honda Fit / modified k20/k24 / 1700 lbs / 24.5x9x15
  3. Vert - CA / 10.19@135.2MPH / CRX K20 / 1825 lbs. / M/T: 26"x8.5'x15"
  4. regamaster - ?? / 10.33@135 / CRX K24 / 103mm Crank / Go Power Cams / Headwork / Custom Go Power Header + Go Power Dogbox / 1738 lbs / MT 26x8.5x15
  5. 1fstHF - NV / 10.46@130.4 / EG VX/Modified K24/K20, Drag Cartel 4.5's, ITB's, K-Pro / 2170lbs / M&H 25.0/8/13 Slicks
  6. Boostedgsr-si - TX / 10.5@126 / 95 Civic Hatch /k24 stock sleeves, sk2-2 / 1750 w Driver / 24.5x15s
  7. HumbleEG - OK / 10.56@128mph / Built K24 / 2172lbs w/driver / 24.5 x 9 x 13
  8. Onefstek aka Stefan @ ASP / 10.72@124.7 / 2150 lbs 2000 Civic EK / 24.5/9/13 slicks
  9. SPL Dan - FL /10.79@127 / EG CX Hatch / Built K24/K20 / 2100lbs race weight / 24X8X13 MT Slicks
  10. H2Nr - MO / 10.82@124 / EG hatch K24 Modified/ Hytech cams/ 2150 lbs / M&H 25/9/13
  11. Marc P - FL / 10.83@125.5/ EG Drag Cartel/ERL K24modified / 2220 / 24.5x8.5x13
  12. Jeremyinlinepro - VA / 10.89@126.99 / EG K20 Modified / 2200lbs / 24.5/x/13
  13. GOTSLICKS - pa / 10.90@128.2 / Honda Insight/ k24-k20z3 / 88-99 stock z3 head,kelforb b,rdx 440,kinsler 62, / 2100 / 23"
  14. Allmotorb18c - NJ / 10.91@122.98 / EG K24 Modified/2040lbs / 24.5x8.5x13
  15. Clockedout - CA / 10.94@121.9 / EG -tube back-half /K24 - stock crank, custom GO Power Cams, Portflow headwork, RCrew Header, K-Pro / 1785lbs / M/H: 25x8.7x13
  16. eg6onboost - NJ / 11.031@122.7 / 24.5x9x13 / 2168 with driver
  17. Tainted - VA / 11.27@123 / Modified k24/20 head/R-Crew header/3"exhaust / 2250lbs / 24.5/9/13 m&h
  18. tsrperf - MD / 11.2@120 / EG K24A1 (Blueprint Motor) / 2161lbs / 24.5x9x13
  19. RacerX023 - CA / 11.2 @ 116mph / 95 Civic K20 Type R / RBC Manifold, stock throttle body, R-Crew Cams, R-crew Header + K-pro Tuned, 650cc injectors / ???lbs / 24.5x8x13 MH Slicks
  20. Marc P - FL / 11.2@116 / EG Drag Cartel/ERL K24modified / 2190 / 24.5x8.5x13
  21. non vtec - NZ / 11.30@118 / EG K20a2 TWM ITB's/SSR 4-2-1/Megaphone/Crower Cams + Kpro Tuned / ????lbs 24.5/8.5/13 M&H Slicks
  22. gotslicks - PA / 11.3@119 / HONDA INSIGHT / BUILT 12.5 88MM K24/20 KELFORD 179B s2pro 74tb / 2115LBS / 23X8
  23. Sicksilver_ep3 - AR / 11.30@ 119.27/ ek hatch/ k24 12.5:1, 4 piston 156, cartel 4's, still on rbc manifold. / 2370 lbs / 23x8x13
  24. Wsuk20 - WA / 11.31@120 / EG / K20, Ross Pistons, Crower Rods, Toda Type 15 cams, SDS management / 1850 lbs / 26/8.0/15
  25. CRXEE8 - Denmark / 11.35@124.7 / EG HB / K24 / 2200 lbs / 23x8x13
  26. cxcivic - FL / 11.40@118 / CRX /TSX w/K20 head/ DTR 4-2-1Header/Kpro + street Tune / 2000lbs / 23/8/13 M&H Slicks
  27. hon+da_b_blastn - Australia / 11.41@119.8 /EG HB /K24 modified/ 2099lbs / 24.5-8-13's
  28. allmotorwhore - CA / 11.41@119.3 / EG K20a2/k24 Sparks Racing header /52MM ITBs /12.7 IB spec pistons Skunk Stg. 1 Cams + Kpro Tuned / 2280 lbs / 24.5-13-8.5
  29. allmtrallday - CA / 11.42@119.9 / EG HB k24 Modified / Excess IM ported out + Kpro Tuned / 2200lbs / 24.5/8/13
  30. Boostedgsr-SI - TX / 305-220 / 11.45@120 / K24A1 DC2/ built, stock sleeves, e85, Kpro / 2300lbs w/driver / 24.5" M&H slicks
  31. K-Unit - NJ / 11.48 @116.53/ EK K20/ rbc manifold/r-crew header/ skunk 2 Pro3 Cams k-pro + Tuned / 2108lbs / 23x8x13 MH Slicks
  32. Palma4dr - NJ / 11.50@116 / K20A2 eg hatch/ Rcrew header, Rcrew Cams, pump gas, Kpro / 2???lbs / 23" M&H slicks
  33. JuanK20 - NY / 11.55@106 / EG Hatch / K24 Modified/ IPS Cams/ DTR Header/ CP Pistons/ PUMP GAS/ K-pro / 2200lbs / 24x9x13 Slicks
  34. ALLMOTAMAK - CAN / 11.59@116 /93 EG/K20A2 RBC, Crower stg2 cams / + Tuning /2120lbs / 23X8X13 M&H
  35. eg6k - NY / 11.66@122 / EG / K24-Hytech, drag cartel stage 4, ips manifold / DRT TUNED 24.5x8.5x13
  36. ldegsick - VA / 11.677@115.30/ eg hatch, k24 modified, rbc mani, stock trottle body, r-crew headers)/ 2325lbs/ m&h 24.5x8x13
  37. 1fstHF - NV / 11.68@116.34 / EG VX/Modified K24/K20, Skunk2 Stg3 cams, RBC IM, K-Pro / 2200lbs / M&H 24.5/8/13 Slicks
  38. dnrprojectsvp - CA / 11.7@117 / K24 ek hatch/ SSR/DTR header, IPS kme, 12.5:1 comp, pump gas, Kpro / 24.5x9.5x13 M&H slicks
  39. NHSwaps13203 - CT / 11.71@113.62 / CX EG / K20a2 + Blueprint2's,RDX injs, Hytech Rep 3inch intake and exhaust / yosolo 238/163 / 2035 / 23x8x13 mh
  40. eg5 - Australia / 11.73@113.17 / EG hatch / K24A TSX stock bottom end (JDMyard IM , 80mm TB , JDMyard Header , Buddyclub N+ cams ) / 2024 lbs incl driver / 24.5x8x13
  41. xtrafastcrx - CA / 11.73@113.3 / eg vx / K20z1 (Ported RBC, 70mm TB) / 2250 / 23x8x13
  42. eg5 - Australia / 11.73@113.17 / EG hatch / K24A TSX stock bottom end (JDMyard IM , 80mm TB , JDMyard Header , Buddyclub N+ cams ) / 2024 lbs incl driver / 24.5x8x13
  43. Trujillokcoupe - NY / 11.743@117.13 / ej1 coupe / k24k20 itbs / 2235 / 24.5x13x8.5 / honda day 2012
  44. dblock - NJ / 11.78@114 / K20A2 eg hatch/ Rcrew header, s2 cams, pump gas, Kpro / 2???lbs / 23" M&H slicks
  45. Jo tech / 11.78@116 / k20/k24 all motor / 2720lb w driver / 24.5x8x15 slick M&H civic 08
  46. SpeedDreamz.com - ? / 11.8@119 / EGk24 Modified / 2280lbs / xx/xx/xx
  47. Midnight Auto - NY / 11.813@114.89 / EG Si /K24/K20 11.7:1CR, IPS K2's, 52mm TWM ITB's, K-Pro / 2340lbs / M&H 24.5/8/13 Slicks
  48. eg5 - Australia / 11.823sec @113.6mph / EG hatch / K24A TSX / JDMyard header / JDMyard intake manifold / 80mm TB / 3 inch exhaust / KPRO/ 2050lbs / MT 24.5x8x13
  49. NHSwaps13203 - CT / 11.84@113.99 / CX EG/K20A2 Open Hytech rep,Blueprint2,RBC,3inch int with Vstack,Yosolo Kpro 238/163 / 2xxx / 23x8x13
  50. Orlando BYTuning - NJ / 11.87@111.6/ EG K24a2 RBC Mani./I/DTR
    Header/E + AEM EMS Tuned / 2210lbs / 25/8/13 M&H slicks
  51. WTFisaK24 - NJ / 11.89@114.3 / K24/K20Modified / Rcrew header, Rcrew Cams, 3" Ex, RBC, Kpro / 2250lbs. / MT 24.5/9/13
  52. gotslicks - PA / 11.9@117 / HONDA INSIGHT / BUILT 12.5 88MM K24/20 KELFORD 179B RBC / 2200?LBS / 23X8
  53. K-Unit - NJ / 11.90@112.65 / EGk24a2 RBC Manifold/Sparks Racing
    Header/ + Kpro Tuned / 2102 lbs / 24.5/8/13 M&H Slicks
  54. Rocket_launcher-Florida/ 11.9@108/ eg hatch/stock k20a2-rbc-E85-dtr header-3 inch exhaust-233hp / 2160/ 23x8x13
  55. Oh K k K - NC / 11.92 @ 109 / Ek Snatch /Z3 Longblock Stock, Full Exhaust, TB,etc../ 2300lbs / M&H 23x8x13
  56. jNYCe5 - NJ / 11.928@114.14 / 88 EF Hatch / Stock k20a2 w/ SSR Race Header and K-Pro / 1945lbs / 23x8x13 M&H
  57. Garenty - Montreal/Canada / 11.93 @ 115.7mph / 1996 EK/ K24 type-s head IPS cams & supertech springs / prb intake / r-crew header / 2375lbs / M/H 23x8x13
  58. Jeff 16 - NY /11.94@114.98 / Ek K24 Modified/2400lbs / 24.5x8.5x15
  59. NABeastRR - FL / 11.98@112 /K24a2/ RRC Mani/KR Header/3inch exhaust + Kpro 243WHP / 2330lbs / 23/8/13
  60. RedEG - TN / 12.03@111.11 /EG HB /Modified inlinepro k24/k20 ,IPS K2, (Blueprint RBC, 70mm Shunk2 TB / h2.NRS MO. tuned K-pro / hytech header / 2360 / MT 22/8/13
  61. dcoghlan-AUSTRALIA/ 12.05@120 / DC5R-RSX / Drag Cartel/ERL K24modified, IPS IM, ASP Header / 2654lbs inc Driver / 24.5x8x15 MT Slicks
  62. WinksK20aHatch - LA / 12.07 @ 111.07 / K20A EG / BC Stage 2 Cams / K-Pro dyno'd (221.56 to the wheels) / 2157lbs. / M&H Slicks 23x7x15
  63. Eg6k20a2-south Dakota / 12.108@114.8 / crx / k24/20 / SvM 211.4 / rbc 74 tb budget header and 2.5 all way back / 2045 / 22x15 slicks
  64. KESE-KMODRSX , NC / 12.19 @112.5 / DC5 RSX /k24a1, GATO IM, KMOD 4-1 Header, Kelford stg.2s, KMOD tuned / 2692 lbs / 24.5 x 8.5 x 15 M&H
  65. jdmchop , CT / 12.1 @112 / eg si /k24a2 52mm itbs,rep header,2.3'' exh, yosolo tuned / 2175 lbs / 24.5 x 9 x 15
  66. eg515 - NJ 12.1/ k20 all motor/ rbc, hytech headers,3inch exhaust,/ yosolo tuned 225 e-town nj
  67. xcell - NC / 12.2@111 / EF K24/k20a2 Hondata IM Gasket/CAI/Hasport header/ 2.5 Exhaust + Kpro Street tuned / 2100lbs / 24.5/8.0/13 Slicks
  68. na200whp - FL / 12.2@109 / RBC Mani/SSR 4-2-1/3inch exhaust + Kpro Street Tune / 2100lbs / 24.5/8/13
  69. dat-dude-ch - NJ /12.2@109 / k20 eg coupe RBC/r-crew header /aem ems tuned /2224lbs / 23-8-13 m&h slicks
    sickcivic51501 - NJ / 12.2 @ 109 / 93 civic hatchback / k20 (rbc manifold, hytech header, k pro yosolo tuned) 2??? 23x8x13 m&h slicks
  70. yosolo - NJ / 12.2@108 / EG K20a2 I/DC TSX Header/E + AEM EMS Tuned/ 2294lbs/ 23/8/13 M&H Slicks
  71. allmtrallday 2nd Car - CA / 12.2@108 / EG HB K20a2 R-crew Header + Kpro Untuned / 2200lbs / 23/8/13
  72. cx-k - VA / 12.2@107 / EG hatch/ K20Z1/ RBC,RDX Injectors, DTR header, KPro tuned / 2325lbs / M&H 23/8/13
  73. gs4 - KS / 12.2x@114 / egk24k20 k2's, 12.5 to 1 c/r, bp rods full weight with ac / 24.5X8X13
  74. Beavis@tsr - MD / 12.228@112.3 / DC5 RSX/ K24 12.5 comp / Ported head / Brian Crower stg 2 / JR custom header/ 3in. exh./ RBC im with vel.stack/ K-pro / tuned by Mike@tsr / 2660lbs / M&H 23x8x15
  75. NHSwaps13203 - CT / 12.29 @111.46 / 91 EF HB/K20A2,RBC,DCRH,BPRNT MFG STG 2 cams/ 2156lbs / 22x8x15
  76. NHswaps13203 - CT / 12.22@111.36 / k20a2 / stg2cams / eg cx / 23x8x13
  77. Damo - AUSTRALIA / 12.32 @ 108.21mph / dc2 / JDM k20a motor + gearbox , JDMyard Intake Manifold + 75MM TB , SSR header + 3 inch exhaust + Metal Cat, KPRO / 2235lbs / 23x8.5x15 slicks.
  78. jorgie583 - ?? /12.34@112.68 / EK hatch / k24 modified / tuned /2300lbs/MH 24.5
  79. BlackEGK20A - Quebec / 12.36@109.37mph / EG SI HB / stock K20A2 CAI / SSR 4-1 / 3" exhaust / k-pro street tune / cusco lsd / 2400lbs / MT 22/8/15
  80. Quiocho8o8 - Hawaii - Maui / 12.41@109 / EK Hatch / K20 K24 Frank K-Pro street tuned 6 speed bolt ons / weight unknown / 24.5-8-13
  81. RS Motors - MN / 12.41 @ 110 / EF K20a2 / Custom header,skunk2 cams,kpro / 2450lbs / 24.5*8*13/
  82. EGhatchNJ - NJ / 12.43@110.3 / EG SI HB / K20A2-3inch int with velocity stack-RBC-SSR header-3in exhaust-KPRO UNTUNED / 24xx with driver / 23x8x13
  83. yosolo 2nd Car - NJ / 12.43@109 / DC2 K20a2 I/R Crew Header/ R Crew Cams / 3" E + KPRO Tuned / 2545lbs / 23/8.0/13 M&H Slicks
  84. flesh199 - quebec / 12.4@110 / ek sedan k24/k20 allmotor 279whp/207tq/ 2578lbs / 24.5x8x13 slick
  85. xtcat8k - VA / 12.4@107 / EK K20AR CAI/Rcrew header/Rcrew PIMP + Kpro tuned / 24xxlbs / M&H 22/8.0/13
  86. 03DC5R - AUSTRALIA / 12.445@109.92MPH / DC5 / Fully Built K24 / 2,643lb / 23x8.5x15 M&H Slicks
  87. kdbatmobile - CA / 12.5@108 / EG / K20A rcrew header, custom intake, k-pro/22x8x13
  88. sleeper6speg - NC / 12.51@109 /93 civic k20a2 kpro tuned/custom 3inch intake with velocity stack/rbc intake manifold/hasport header/apexi 2 3/8" n1 exhaust / 2150lbs /M/t: 22x8x15
  89. Brentd2319 / Hybrid-Werks / 12.52 @ 108.91 MPH / 93' EG coupe EX full interior STOCK K20Z1 motor (stock intake manifold & TB), ITR transmission - 8x23x13 M&H RaceMaster slicks.
  90. 6spd EK- VA / 12.57 @ 107.7 /EK Hatch/ K20A2 (K-pro, SSR, Velocity Stack) / 23XX lbs / M&H 22x9x13
  91. VTX Aviator - FL / 12.578@107.26 / EK Sedan / K20a / RBC / R-Crew header / CAI / tuned / 2450 lbs / MT 24.5x7.13
  92. yeven_stas - WA / 12.58@106.99mph / eg / (stock k20a2 220.170 / asp header/ ported rbc/ 3in cold air/ kpro Asp tuned)2300lbs / 22x8x15
  93. MarkyMark203 / 12.60 @109mph / EK Coupe / stock k20z3 11.7:1 UNTUNED / Lightened. Lexan. 22" Lensos / 22x8x13 m/t
  94. Sicksilver_ep3 - IL / 12.623@ 104.72 / ek hatch/ k20a bp stg 2, dtr 4-2-1, 3 inch, RBC, vstak, / 2400 lbs / 23x8x13
  95. dc2eg6 - CA / 12.66@ 105.4 / EG CX / K20A2 R Crew headers + k-pro(R Crew Program) / 2xxxlbs / MT 22/8/13
  96. ek20hatch - ?? / 12.7@107 / EK k20a2 Rcrew header/CAI + Kpro Basemap / 2xxx lbs / ??/??/13 M&H Slicks
  97. tony4380 - GA / 12.70@107.40 / k20a2 crx hf / DC swap header / custom cool air intake / 3 inch exhaust / KPRO on air fuel tune / 2150lbs / MT ET Drag 24.5x8.0x13
  98. NA - VA / 12.7@105 / EK K20a2 Rcrew header/CAI + Kpro Base Map / 2475lbs/ 22x8x15
  99. JustinD - AZ / 12.76 @ 106 MPH / EK / K24a2 / IPS KME's / Cunningham Rods / JE 12.5:1 Pistons / RBC / CAI / SSR Header / Kpro Tuned / 2220lbs / 24/8/15 Mickey Thompson Slicks
  100. Pistol Pete - Toronto / 12.78@106.55 / K20a2 EG SI/ Drag Cartel DIC/RRC /70mm TB/CAI/ K-Pro /K-Tuned Ram Header/ 2400lbs / MT 22x8x15
  101. boosted98acura - PA / 12.78@108.7mph / 1998 DC4 stock k20a2/kpro/Z1 cams/3in exhaust/Hytech rep. header/ 230whp 169wtq / 2580lbs w/driver / 22x8x15
  102. import_boi - WI / 12.78 / eg / k20a stock motor, stock trans with ghetto rid cold air, dc sport headers, exhaust. rims 15in with mt 24.5x8
  103. Bboy_Burst - CA / 12.8@107MPH / FG2 / K20Z3 (I/H/K2/FP/TB/PM/OP/FD/IMG/MM) / 2900LB / 23-7.5-15
  104. 92EGK20 - NY - 12.81 @ 107.23/ '92 EG Sedan/ K20z1(BP stg 2 cams, RBC, Hytech header, 2.5" exh, Type-R LSD, K-Pro) / 222whp/175wtq / 24.5x8x13 MT slicks
  105. Charmersfh - Minneapolis, Minnesota / 12.831 @ 105.98MPH / 1993 Civic Si (K20R, RBC IM, R-Crew headers, K-Pro) 222HP & 159TQ / Full Interior weight 2350(?) / 23x8x13's
  106. k20eg8 - OK / 12.84@103.4 / EG sedan k20a2 R Crew Header, PIMP, intake/ kpro tuned 212hp/162lbft/ 2550lbs/22x8x13
  107. KYjerry414 - KY / 12.86@107.26 / EG SI / RBC manifold / K-pro street tuned / 2600lbs / M&H slicks 22X8X13
  108. Crx2nr822 - CA / 12.87@105 / 88 Crx HF / K20a (3 in. custom intake, SSR 4-2-1 header (open header), Tuned on Kpro) / 2160 with driver / 23x8x13 M/H slicks / Stock Type R 6speed w/ stock clutch
  109. Mike@ETD Racing - CAN / 12.89@106 mph / EG hatch / K20A2 w/RBC & KPro base-map / 2180lbs / MT 22x8x15
  110. Jdm_risa - CA / 12.99@104.78mph / DC2 stock k20/kpro/3in cai custom/3in thermal exhaust/rcrew header/ 2700lbs w/driver / 22x8x15
  111. Redlinef22c1 - LA / 12.99@108.95 mph / EG hatch / K20A2 w/RBC & KPro base-map /DCRH / Apexi WS2 / 2000lbs? / M&H 23x7.5x15
*Cut Off is 13.00 People*
If you guys have any suggestions on how maybe to list this better feel free to chime in. :up:
ALSO PLEASE DON'T PM ME YOUR TIMES, POST ON THIS THREAD, AND WHEN I OR THE OTHER MODERATORS ARE NOT BUSY WE WILL UPDATE IT!
Also please people, if you want your times entered in this registry please please please follow my format... give me your exact parameters that i am asking for, if not then you will not be entered until done so.
#52 ·
Re: Official Registry: Quarter Mile Quickest All Motor Times On Slicks
dnrprojectsvp said:
dnrprojectsvp - CA 12.2@109 /K20a2 EK hatch/K-Pro/DTR Header/22x8x13 M&H slicks
Great times bro! Could yo u tell me what your weight was? And was this through an exhaust? If so what exhaust? And are you tuned?
#54 ·
Whoops! Could you go into more detail on your setup? Like slick size width, along with teh wheel size you went with, and the header your using, if your tuned, along with if this is coming out of an exhaust or not. And any other mods you have done.And also if its a k20a2 or K20aR motor.
#55 ·
13X8 m&h's, DTR4-1, street tuned, no exhaust(it has a megaphone), internally stock k20a2, prc intake mani. This was last year when they didnt have a weight limit in Comp4. Now im running a k24a2/k20 head, same cams, runs the same time(11.65), new SSR 4-2-1. Right now its on a basic tune, smoothed the air fuel, only have k-pro set at 30deg cam adv. She went 12.4 on BFGs first pass(crappy), then pooped a mount on the second pass. The mount is fixed for good now, I just have to bring the car up to weight and she is good again to compete.
#57 ·
H2nr said:
can you please update the list?
11.45@120, 2200lbs, crower 2 3/4, Bfab header, street allmotor 92egK24, MO
Yep just was waiting on the rest of your info, now that i am recieving most of it i can enter you. Also what ECU are you using? Kpro right? I also saw you had some sort of Non Stock IM? What type was it? Looked to be a BDL style Manifold. What size slicks?
Also please people, if you want your times entered in this registry please please please follow my format proivide your exact perimeters that i am asking for you guys to provide me with, if not then you will not be entered until provided so.
#58 ·
Im going to guess and say these are the 23inches tall M&H Slicks? Also the weight is still 2000lbs with driver as you provided before? And there is no exhaust correct?
#60 ·
2200-2300lbs never weighed it. with no exhaust. tuned k-pro
#61 ·
1.72 -60ft
5.038 -330
7.805 -1/8
88.10 -mph
10.22 -1000
12.22 -1/4
109.3 -mph
k20a, k2 cams, SSR 4-2-1, 3in exhaust, RBC , kpro calibration w/ street tuned A/F, 2100 lbs , 13/8/24.5 M/H ,FL
#63 ·
na200whp said:
1.72 -60ft
5.038 -330
7.805 -1/8
88.10 -mph
10.22 -1000
12.22 -1/4
109.3 -mph
Added bro.:up:
SpeedDreamz.com said:
SpeedDreamz.com EG, 2280 w/driver, 11.84@119 at NDRA Valdosta. Driver Stacey H.(my wife). Modified K24
Pretty quick man! That trap should net you more close to 11.5. What Mods are done to the motor if you dont mind me asking? And what 60 fts was your wife pulling? Also where are you located and what slick size was used during the run?
UPDATED
#69 ·
Just came back from the track met matador and alias had a good time out there matador runnin some good numbers on real street tires also i ran 11.90 at 112.65 with a stock k24 just headers and exedy on k pro with 24.5.8 .13 m&h with a 1.6 60ft:up:
#71 ·
cxcivic said:
new time...11.54@116, new motor, k24a2 stock bottom-end and k20a top, new header SSR 4-2-1 no exhaust. everything else the same.
Interesting. In the beginning i had you listed as just a k20a2 with just a DTR 4-1 not even a 4-2-1. So now oyu have a PRC head with cams and all that? And a k24 Bottom end?
Updated.
#73 ·
Updated.
that was in the begining....now i have a tsx bottom, same top end. PRB head, PRC cams and intake mani. Also had to buy a new SSR header for the k24 setup.
More goodies soon, should be getting faster.
#75 ·
wsuk20 said:
Wsuk20 - WA / 11.31@120 / EG / K20, Ross Pistons, Crower Rods, Toda cams, SDS management / 1850 lbs / 26
Which toda cams? What comp pistons? And how wide and what size rim on the slicks? :up:
