K24A2 Oil Pump Rev Limit?
45K views 36 replies 19 participants last post by  texm3x
While you can force the oil pump to spin at what ever RPM you desire, it does not mean that it is operating effectively. Hytech and ERL have both tested the OEM oil pumps, as have others, and they have found where cavitation occurs in them. I recommend reading this thread, there is some good info regarding this topic, as well some other good tid-bits of info.
http://k20a.org/forum/showthread.php?t=10000
:up:
is 7500 for all k24 oil pumps or just the tsx, what about the crv pump, will it handle 7500?
It is just a general, recommended ceiling for the pump.
The weight of the oil can change what the limit prior to cavitation is.
Perhaps the extra rotating mass of the balance shafts may play a role. Perhaps they are not tested past the OEM rev limit on the K24 from the factory, and vibrate. I don't know, I haven't tested it. Just another unknown.
There are other factors to take into account as well, but personally, I would spend the $150 for a new K20 pump and know that I can take it to 7500-8000 RPM safely.
