K20 or b18c1
K20 swap to 1990 da integra
8.4K views 9 replies 4 participants last post by  LotusElise
What do you plan on doing with the car? Based on its stance I’m guessing you just cruise around with it and go to shows. If that’s the case stay B series. Will be much cheaper and give you plenty of power.
if your looking at getting started with time attack or track events a motor swap would be last on my list, unless there was a problem with it. Suspension, tires, and seat time will make you faster than more hp will. I have run lower lap times in my 150hp powered cars than cars with far more hp.
With that said B series engines and transmissions have been getting more and more expensive. A B series will be easier in your car, if you plan on doing it all yourself, but finding B series that won’t need to be rebuilt can be a challenge as well. A K series can be as easy but you will need to spend more money on premade harnesses and parts to make it more plug and play.
