I have found that trying to follow the spread out information on this subject very frustrating. So this is going to be my attempt to organize it.
First off what is needed:
S2000 Cluster
Wire pig tales for S2000 cluster
Modifry AP2 stock ECT converter
http://www.modifry.com/products/ect/ap2.htm
Speedohealer V4 universal
http://www.pashnit.com/
The wiring is pretty straight forward. First off label the factory EG cluster wires. You will only use the top two plugs in the diagram A and B plugs. You will also use the E plug if you have airbags.
After that I labeled the S2000 cluster. There are a lot of pins that you don't use. I just unpinned the extra pins from the plugs so there was less clutter.
Sorry the pictures are hand to see but here we go
EG
Plug A --------to----------- S2000
A1 Blue/White Seat belt indicator to B4 Blue/Red
A2 Green Trunk indicator to A12 Blue/Black
A3 Yellow Ignition Power to A1 and A9 both Yellow
A4 Yellow/Green ECT sensor to Nothing
A5 Black Ground to A17 and A18 both black
also to A16 Red/Blue
A6 Green/Orange Check Engine Light to B28 Green/Orange
A7 Blank
A8 Antilock Brakes----------------------Do not have it------------------------
A9 Green/Red Brake Indicator to B23 Green/white
A10 Red/Green High Beam Indicator to A15 Red/White
EG
Plug B------------to------- S2000
B1 Yellow/White Fuel Sender to B10 Yellow/Black
B2 Yellow/Blue Vss to Speedohealer
B3 Green/Yellow Right turn to B30 Green/Yellow
B4 Green/Blue Left turn to B29 Green/Red
B5 White/Blue Battery Light to B26 White/Blue
B6 Yellow/Red Oil Press. Ind. to B27 Yellow/Red
B7 Blank
B8 Blue Tach to B3 Blue
B9 Blank
B10 Black/Yellow SRS fused Ignition to Nothing
B11 Red/Black Parking Lights to A8 Red/Black
B12 Red Dimmer to Nothing
EG-------------to-------- S2000
Plug E
E5 Blue SRS Indicator to B19 Pink
---------------------------------Modifry ECT to a PRC Ecu-------------------------
Modifry Unit
White to B8 on PRC computer Red/White
Green to B5 on S2000 cluster Yellow/Green
Yellow to A20 on PRC computer Yellow/Blue
Brown to Ground
Gray to Alarm (not used)
Black to Ground
---------------------------------Speedohealer--------------------------------------
Speedohealer
Red to Ignition Power A3 on EG cluster
Black to Ground
Green to B7 Blue/White on S2000 cluster
White to B2 on EG cluster plugs
---------------------------------Other Notes----------------------------------------
Connect A3 and A10 both White/Red on S2000 cluster to a hot all the time 12V source. You will have to find one I used the hot wire at the clock in the dash just because it was right there.
You also have to connect B20 Blue/Red on the S2000 cluster to ground to turn off the ABS light.
This cluster completely works in my car so all wires are tested and verified. The only problem I see is if I typed something wrong.
S2000 Cluster
EG
A7 Blank
EG
B7 Blank
B9 Blank
Plug E
Modifry Unit
Brown to Ground
Black to Ground
Speedohealer
Black to Ground
