Ok, so I have done 3 different pulley setups for my own car, and 2 friends...
1. k20a jdm with the 507039 gates belt, and str alt pulley
2. k20a jdm with the 507039 gates belt, and aem pulley
3. k20a2 usdm with 507039 dayco belt and bdl pulley...
so, to get tension on the pulley on number 1 and 2 I had to use washers... last week my top bolt sheered off, and now I have to fix it.
My friend with the typeS usdm a2 dosent need to washer shim out his alternator??? It fits with correct tension flush to the water pump housing. Why is this?? It almost looks to me like the crankshaft pulley is a different size??? is it?? That could explain everything...
All the alternator pulleys are the same size fyi...
If anyone has input, post it up!
-Ryan
-Ryan
