NOW CURRENTLY THE FASTEST STOCK BLOCK DRAG RADIAL RSX IN THE COUNTRY
Figure I would post up my DC5 build and some pics of the car for you guys. It's pretty simple, I like it that way. :new_slayer:
When I first got it, AEM SRI was the only mod done, took that out for a Injen CAI as my first mod, lol.
Mods are as follows....
Engine
Custom 4" CAI w/ BPI Velocity stack
Kidd Racing Race Header
Greddy Ti-C 70mm Catback Exhaust
RRC Intake Manifold w/ Hondata IMG Ported by ASP
Drag Cartel 2.2 Cams
Supertech Valvetrain Kit (Springs/Retainers)
NGK Plugs
KPRO Tuned by Chris @ Xenocron Tuning on E85
Suspension + Brakes
Eibach ProKit Lowering Springs
Koni Yellow Shocks
Eibach Rear Swaybar 23mm
Hotchkiss Rear Endlinks
Powerslot F/R Slotted Rotors
Hawk HPS F/R Pads
Goodrich SS Lines all around
Energy Suspension Front LCA Poly Bushing Kit
Ingalls F/R Camber Kit
Ingalls Torque Damnper
Innovative 75A Motor Mounts (3 of 4 installed)
ES MM inserts on R Motor Mount
Front Extended Wheel Studs w/ Spacers (Have to run for 15's)
Rota Circuit 10's w/ 225/45/17 Dunlop Direzza Star Specs (Street)
2x Team Dynamics Pro Race 1.2 15x7.5 w/ 225/50/15 Hoosier Drag Radials (Track)
2x Stock RSX 17s w/ 215/45/17 for the Rear (Track)
Looks
6000K HIDS
Yellow Fogs
Removed Acura RSX Type S emblems
Transmission
Strut King Shifter Bushings
Comp Super Single Clutch Kit w/ LW Flywheel
Omni Power CMC w/ SS lines
Hybrid Racing Shifter Cable Bushings
Skunk2 Shift Knob
Redline MTL
http://www.youtube.com/watch?v=jzzeJDJyBHw&feature=share&list=UUt30_EIe8IUaFiuFD4u9iSg - Track Runs
www.youtube.com/YonkersRacing - All my runs
I've been to the track once on this setup and managed to get a good 10-12 runs in that day. Best time was a 13.8 @ 104 with 5 slips in the 13s. Since then I added the Omni Power CMC which should improve my second gear issue I was having at the track but I'm not sure I will make it back on this setup again. I am planning on adding a HR 74mm TB, ported RBC and DC 2.2's w/ Super tech valvetrain.
Edit - Traded my uncut RBC + cash for a RRC, which is now being ported by Stefan @ ASP.
Hope you enjoy the pics.
Engine
NGK Plugs
Suspension + Brakes
Koni Yellow Shocks
Hawk HPS F/R Pads
Looks
6000K HIDS
Yellow Fogs
Transmission
Skunk2 Shift Knob
Redline MTL
