1 - 13 of 13 Posts
Parts I still need: K20A2 throttle body, intake, clutch line, fuel lines, alternator, bigger fuel pump. Probably missed some other stuff but can't be too much left.
Hey guys, I'm trying to collect the rest of the parts I need for my 04 TSX K24A2 and 04 Accord 5 speed swap into my 95 EG hatch. So far I have the engine and I'm picking up the tranny on Saturday. I'll need mounts, ECU with kpro, swap header, K20A2 engine harness, charge harness and conversion harness, shifter box/cables, base RSX axles, Accord or K20 cable throttle body, etc. I'm sure you guys have a better idea of what I'll need than I do. I'm just aiming for a running, driving swap at the moment, so I'm not really after any performance parts per se. Thanks! Oh, and I'm in Vermont zip code 05201 for any shipping quotes.
I have a kpro ecu, k20a2 engine harness, shifter box/cables, base rsx axles, k20a2 throttle body. message me if still interested! or text me for faster response. 530-710-3003
Parts I no longer need: Engine, transmission, ECU/KPro, engine harness, clutch and flywheel, AC/PS delete kit, and fuel rail.
Super Moderator
Selling for $150... Pm'd ya........ K-Tuned Conversion harness for EG/DC Chassis
Parts I still need: accord throttle body or k20 TB with adapter, intake, rsx-s knock sensor (and crank sensor?), charge harness (may DIY), swap header, clutch line, fuel lines, alternator, accord shift cables. Probably missed some other stuff but can't be too much left.
I have a charge harness, engine harness and throttle body cable. Also largely throttle body adapter. All parts never used. Installed only and project came to a grind. PM me.
Discussion Starter #12
Got my K-Tuned TSX shifter base and cables are on the way. I need the bracket that bolts to the transmission that holds the cables in place. The junkyard I got my tranny from must have decided they needed it more than I do.
Discussion Starter #13
Found that bracket for the shifter cables on the accord/tsx tranny. The part number is 24601-RAP-010 in case anyone is looking in the future. It was a bit of a pain for me to find.
1 - 13 of 13 Posts
