1 - 4 of 4 Posts
whats the rev limit on a k24/k20a2 swap and how much tq and whp has been recorded with a bone stock swap. compared to a k20a2 stock what are the differences. and those who are in california and have sucessfully swapped in this motor or any kseries, how did you pass smog? what requirements did they give u?
Banned
read this
http://www.k20a.org/phpBB2/viewtopic.php?t=462&highlight=scc
you will see the part where it says
Our 2.4-liter mustered 30 lb-ft more torque across the rev range, leading to a power increase between 15 and 30 hp all the way from 2000 rpm to redline. Is this free power? Basically. The added displacement is good for more than a 25-percent increase in torque throughout the rev range, with no loss of driveability. The hybrid can even drink the cheap gas, thanks to the lower compression ratio. True, you can't impress yourself with an 8000-rpm redline, but that's a small price to pay for going faster. Using the K24 block not only adds torque, but the hybrid's lazy 9.6:1 compression ratio cries out for supernatural aspiration. And remember, it doesn't take much boost to make insane power with 2.4 liters. We like this mod because you get great results from stock parts. Especially if you already have an RSX Type-S or anything else with a K20A2 stuffed into it, you'll be hard pressed to find another bolt-on that nets as much power for the price. So the adage is correct; there is no replacement for displacement. We've just combined it with a dose of modern engineering to prove it once and for all.
1 - 4 of 4 Posts
