Hey people.Well i got a 91 civic standard and its dpi just wondering if when i do the k20a swap would i need to find a civic mpi harness or can i send out the dpi harness along with the k20 engine/charging harness :up:
brian had told me that the conversion harness for the EF's didnt require any core harness from the customers.crsx said:If you want a hasport harness you need to send in your crx engine harness. so dont trash it.
So i can buy a modified harness from hasport to work with my car without sending them a core.So basically itll be all plug an play :up:jNYCe5 said:brian had told me that the conversion harness for the EF's didnt require any core harness from the customers.
Unfortunately, that is not the case at this time..jNYCe5 said:brian had told me that the conversion harness for the EF's didnt require any core harness from the customers.
locash said:Unfortunately, that is not the case at this time..
Cores are currently required for this swap..
uneeklady said:yes they are i just gave hasport mine i live right next to hasport and they said i need my crx core
