there is three holes in the mount about the size of 10mm head bolts..
after you drill out the stock mount bracket, you will see that the hasport mount bracket will line up using those three little 10mm bolts, i beleive those holes were for the clutch line bracket, and after those are on you will see that the hasport bracket lines up with the bottom mount holes, under the frame..
