yes you will not have the use of the heater anymore. If you are still going to keep the heater core, you will most likely have to drill a hole. See the pics from the post a made above.sloboy_hatch said:with taking out the heater core you will no longer have a heater right? I also sawq that the the hondata car had them running near the header under the car.
correct. there are plenty of areas where you can drill a hole that will not interfere with your heater core. for instance the area right in front of the hole for the old/stock shift linkageTrueZen said:Okay, just need a little clarification for myself. If I drill the hole through the firewall like what was previously posted I will still be able to keep the heater core, correct? This is on a EG CX hatch.
Those pics were very helpful while i was installing my shiftlinkage, but i think the drill bit size may be a typo.taqman15 said:since I removed my a/c, I ran the cables through the hole wehre the heater core went. That way I didn't have to drill any holes. Katman actually drilled a hole.
Katman:
yeah yeaah...
here's some updated pics of my shifter cable routing:
http://www.ff-squad.com/tech/k20stuff/shifter.cable-routing.01.jpg
http://www.ff-squad.com/tech/k20stuff/shifter.cable-routing.02.jpg
http://www.ff-squad.com/tech/k20stuff/shifter.cable-routing.03.jpg
yay.
