1 - 6 of 6 Posts
I will make this simple
k20a2 head ( crower stage 2 kit ) mild valve job
k24 block sleeved, 12:5-1 built
kpro
stage 2 clutch
itr-itm
intake unknown yet
correct sized injectors, fuel pump
and lets say its tuned properly
What do you think this will do?
nikos said:
That is a very good question.. We just don't know..
I would like to think 250-270 on ITBS but someone needs to try it and talk about it too.. :p
You need at list 440cc or 550cc is better...
It should make around 240whp+ and 170tq no problem...
hmmm. o.k. first off I bow down to your knowledge on all things Honda (well compared to me lol) but wouldnt that motor without the additional head tinkering make around 170 torque? My guess for the whp would also be around 240+
I think the porting would be the key to the motor. Mainly because with having bigger combustion chambers you can port the head more than a 2litre a get better results..
I would like to think the motor would make 260whp with ITB's 560cc injectors etc.. BUT being the 2.4 no-one really knows how well it will rev, and that might be the down fall..
Thank you...
Ya when i said no problem...it should make way more then that..
I think the most you can with that setup it should be around....198wtp not at the crank...
1 - 6 of 6 Posts
