gsr hoses CAN be used but like i said before they rub/rest on the intake in most cases and thats not preferable to alot of people.. its much easier to get one you can bend to your own needsk20spooner said:ek uses gsr hoses if im not mistaken, the lower one needs to be shortened
I'm using an RSX radiator.vuaccordla said:what radiator are you all using. I know the the civic dx,lx,etc and 99 si radiators have a difference. have you had any cooling issues with the regular civic radiators? What about the fan did you have to buy a slim fan and mount it in front of the radiator?
same hea! used dc5 rad and ep3 upper/lower rad hoses...works like oem!!!katman said:I'm using an RSX radiator.vuaccordla said:what radiator are you all using. I know the the civic dx,lx,etc and 99 si radiators have a difference. have you had any cooling issues with the regular civic radiators? What about the fan did you have to buy a slim fan and mount it in front of the radiator?
Use to have a DC2 radiator in my EG, and suprisingly, the RSX rad is a direct replacement =). Uses the same mounting points and everything..its suuuupeer!
...I assume you have the upper rad hose crossing over the top of your intake pipe, eh?K20DC2R said:same hea! used dc5 rad and ep3 upper/lower rad hoses...works like oem!!!
