1 - 10 of 10 Posts
Is there a difference between the k20a2 block and the k20z1 Block? I know the cranks are identical just wasn't sure if the block were the same or Not? I know as far as the complete motors go the main difference is the cams and p istons. Any help would be greatly appreciated!
Aside from the engine stamp, the short blocks are about 99% the same (same rods/pistons/oil pump/water pump housing etc). Only difference is the crank pulley size is smaller diameter on the Z1.
A2 = 5.80" dia.
Z1 = 5.5" dia. (same size as JDM DC5/EP3 K20A pulley).
Discussion Starter #6
A2 = 5.80" dia.
Thank you much! I have been looking for a a2 block and crank to send out to get sleeved. I found a z1 block and crank that a friend is giving me for 300 bucks. I just wanted to know if there were any significant differences. I appreciate your help💯
Is this some kind of nostalgia, or something? This discussion isn't actually happening right now, is it?
K20Z1 has Type-R cams. Old news, like decades old news (ok just 15-16years).
K20Z1=K20A2 + Type-R cams + Type-R crank pulley
The cam difference is duration, between K20A2 and K20Z1/Type-R. Who cares about the centerline. The valves stay open longer because the duration is longer.
I have to correct something, to clear that misunderstanding.
There is one who was asking for the differences. Not sure if he asked for a nostalgia discussion 🤔?! He definitely was not asking for the cam differences, this was something you brought into the discussion.
05-06 DC5 has the better cams!
I commented on that, because I wanted to point out the DC5 came with different engines on the market: K20A3, K20A2, K20A and the K20Z1. USDM relevant are only A3 (02-06), A2 (02-04) and Z1 (05-06). I assume you were pointing on the Z1 engine, but for someone who is asking what are the differences of the A2 and the Z1 it might be not clear. Therefore I made clear which cams we are talking about. And if you read my post again you will know I was comparing the ITR (K20A engine, cam part #1411(2)0-PRC-000) and 05-06 DC5 Type S (K20Z1 engine, cam part #1411(2)0-PRC-030). Those cams are compared by valve lift measurement the same beside the intake centerline difference.
The cam difference is duration, between K20A2 and K20Z1/Type-R. Who cares about the centerline...
That's indeed correct, something 6spd_EK measured by valvelift variation in 2013 I believe, but that wasn't my point. If you look into the part numbers you will know I was talking about the K20A cams vs. K20Z1 cams.
1 - 10 of 10 Posts
