1 - 3 of 3 Posts
gotta make one
What box do you use to ship the engine?
Can anyone help.
Thanks.
If you can get a shipping palate, that's a good plate to start. The best I've seen was where someone took a standard shipping palate, then they took off the upper boards and replaced it with a sheet of mdf. Then they built a small mdf box that the oil pan sat inside, and that supported most of the motors weight (the motor was resting on the girdle, where the oil pan bolts to, not on the oil pan itself). Then They added some pieces of bent 1/8" steel that bolted to the palate and the motor, to stabilize it. There were about 4 of those. Then they built a big 5-sided mdf box that encased the whole engine and screwed to the palate. It was a think of beautify I tell you.
peace,
russ
1 - 3 of 3 Posts
