1 - 6 of 6 Posts
I purchased a lot of K parts and I have questions on what the following parts are.
I think this had to do something with an oil baffle?
This is a hasport coolant coupler. It is designed for 2 parts. Both seem to measure coolant temperature? There is a larger switch (not shown) and the smaller switch?
HONDA HEAVEN RIP
timing chain guide in pic1
coolant temp sensor for the cluster is for the small hole
fan switch is the larger hole.
each sensor can be taken from a b/d/h motor.
As for the temp sensor, for the cluster. What will happen if that wire is not connected? The factory cluster will not work?
the temp gauge (hence temp sensor) in the cluster will not work...
the rest of the cluster will work if it is hooked up properly...
Discussion Starter #6
Well, I should have asked. Will any other part of my system NOT work because that plug is not plugged in. The reason why I ask is that I am running a stand alone instrument cluster that uses its own sensors. I am basically going to do away with that sensor.
1 - 6 of 6 Posts
