c_buz said:
I am very confused about this topic. Can anyone elaborate?
I realize most everyone knows this, but just in case, here's the background information.
The K-series engines don't have a water temperature sending unit for the water temperature gauge in the dash. The information is fed to the multiplex through a communication wire from the ECU and then the multiplex sends the information to the dash.
The K-engines also lack a radiator fan switch like the earlier engines. It's found in the bottom of the radiator.
Ideal placement for the temperature sender is on the head, or the second choice would be the upper radiator hose. If for some reason the water pump quit (no belt) the head and engine would get hot first, followed the upper radiator hose, and last the lower hose.
The ideal placement for the radiator fan switch is in the lower radiator hose or bottom of the radiator. That way if the radiator is doing a sufficient job of cooling with out the fans on, (like when you're moving) they don't need to come on.
k20girl said:
Brian are there any negative effects of not using the air assest? I noticed on your ek that you didn't use it but I think your dc did.
It's an emissions device. You may or may not pass emissions without it.
k20girl said:
By the way I have a k20a2 in a dc chassis using Hasport mounts. If I were to change over to a k24 block in the future would i have a hood clearence problem? It looks as if there is more room in the integra than the eg.
You're right there is more hood clearance in the DC2. We didn't have to trim the hood to close it.
brian g
________________
Thanks for purchasing Hasport mounts!
