huh?hondata said:The JDM engine does not have the oil pressure sensor and also the JDM harness does not have the connector.
Easiest solution is to disable the error in the KManager software. If you really want to know 4 seconds after the head loses oil pressure, you'll need the US harness and US pressure sensor.
iwilson said:huh?
New harness - why? And yes I do want to know if the head loses oil pressure even if it's 4 seconds after the event. Because the VTEC pressure sensor triggers when you still have a reasonable amount of oil pressure. Unlike the main oil warning light which simply informs you that you're screwed. If the engine starts to drop out of VTEC due to a drop in oil pressure it's a sign that you need to sort the oil system out. Without it your first indication is likely to be a death rattle as your bottom end gives way, followed shortly thereafter by the oil warning light coming onFrankly I'm surprised you recommend disabling the function in Kmanager and I'd like to know why you feel this is the correct approach.
Again, there is no need to replace the entire harness, so how can it be correct? I have fitted this sensor to my JDM and I certainly feel more comfortable in the knowledge that the sensor is there.ebrow21 said:He didn't say correct, he said easiest.
The second solution he suggested on the other hand (regarding the harness) wasn't the easiest; it was the correct one.
E.J.
I agree and have done so. But the majority of people don't. And if they do, in most cases they fit a standard single wire gauge of dubious accuracy that has no warning light. The typical scenario for a drop in oil pressure is under high G's which is precisely the time when the driver is concentrating on where he's going rather than looking at an oil pressure gauge. Fitting the VTEC oil pressure sensor is cheaper and provides a warning you cannot ignore.hondata said:The VTEC oil pressure switch does not do anything useful. It just rev limits the engine a little while after the engine has insufficient oil pressure for VTEC and drops to the low cam. If you want a warning for low oil pressure I'd suggest an oil pressure guage with adjustable warning light would be a much better investment than wiring up the VTEC pressure sensor.
Garet Jax said:I have both the US harness and the US pressure sensor on my K20A.
