Hey guys,
K24 with Drag cartel 3.2 cams, currently testing the vehicle with only 10deg VTC in high cam, and conservative ignition timing before going to dyno, however, in the midst of testing, we're finding that the VTEC engagement is intermittent and it engages and disengages VTEC.
Is this due to not having enough VTC on the crossover? Or would this suggest other issues?
Here is a photo of the log where the issue is happening;
Trying to sort out the disengagement issue bringing to dyno, any ideas would be appreciated.
As soon as it revs past the hesitation, it revs out nicely to the limiter 😂😂😂😂
Thanks in advanced!
- Low cam and high cam maps are both at 10deg VTC at crossover
- Crossover is at 5500 lower / 5750 upper
- Low cam is fully dyno tuned at 12.5 AFR, have copied low cam fuel and added 15% for high cam fuelling
- Low cam IGN is 25 deg and high cam is 25 deg
Thanks in advanced!
