I've got a K20Z3 in a road racing car and looking for some help troubleshooting some issues that came up this past weekend. The engine ECU is a Motec M1 and I have full logging so I can see a good bit of data as to what is going on. On track, I noticed the engine go from performing very strong at the beginning of the weekend to being noticeably down on power by the final session. The engine just didn't feel as strong at the top-end, like dragging an anchor or fighting a huge headwind vs. early in the weekend. Other than that, there weren't really any other big symptoms - engine started and idled fine, no weird noises, etc.
In looking through the data, I think I've found the symptoms but looking for help as to what is root cause? See attached snapshot of the logging data showing areas where the VTC Phase tracked pretty well vs. the Aim and then other times where it swings wildly and drops-out completely with gaps. The only correlations that I can see here are:
Any thoughts as to what would cause this? At first, I figured the data drop-outs had to be a bad sensor or wires. But with the oil pressure correlation, I'm wondering if this is related to the VTC Solenoid/Screen and/or tensioner? I plan to pull the motor and inspect all of these. Would love any thoughts on what to look for and what is the most likely cause?
Thanks in advance.
Dave
K20Z3
AT Power ITBs
Drag Cartel 3.2 intake/2.2 exhaust
12.4:1 CR
- Seems to drop-out whenever RPM > ~7,000 rpm
- Oil pressure doesn't look too bad to me in general, but the drop-outs seem to correlate almost exactly with GOOD = >~82 psi and BAD = <80 psi. I wouldn't think it would be that sensitive, but it really does seem to hold true across all of the data. Data from earlier sessions where it performed better and had perfect VTC Phase tracking the oil pressure rarely dropped below 86psi.
Thanks in advance.
Dave
K20Z3
AT Power ITBs
12.4:1 CR
