1 - 4 of 4 Posts
90 crx with kpro prb ecu. i switched to a gsr cluster and electronic vss back when i had a b series, so i know for sure that the cluster works.
I am throwing a code 17, and my speedometer is not working. I am using the Rywire harness, and i asked if i needed to run extra wires to my cluster, and he said no.
so anyone else have this problem or are you still using the cable and not electronic vss? :confused:
I am having similar problems in my EG.... once in a while my cluster will go crazy and jump all over the place. Sometimes it goes dead, other times it work fine. I am also running a K-PRO ECU.
have continuity from the vss to the back of my cluster, which in turn should mean it it connected to the kpro correctly. bad vss?
1 - 4 of 4 Posts
