1 - 6 of 6 Posts
unless you are bumping up compression and doing porting and or valve or bowl work it's probly not worth upgrading to a bigger valve for a mild setup which it sounds like you are going for...
for a standard size valve you might as well keep the OEM valves and spend your money somewhere else
that would be my 2 cents
The only head work i want is a gasket match. i'll be running 10.5:1 C/R k20a2 block with K24a2 head, Plus JRSC @8psi.
i'd just stick with the OEM valves if it was me...
If you are going to get port work and or a valve job down the line, then it may be worth it, if it would even compliment the rest of your setup...
1 - 6 of 6 Posts
